Hand brake light
Hand brake light was created by sherwood0_8
Posted 13 years 5 months ago #102947
Just a quick one my hand brake light has never worked since I have had the car I did start to look into but had no luck, when hand brake is pulled up no light comes on any ideas??????? could it be as simple as the bulb has gone ?
Last Edit:11 years 9 months ago by sherwood0_8
Last edit: 11 years 9 months ago by sherwood0_8.
Replied by Freestyle on topic Hand brake light
Posted 13 years 5 months ago #102956
Wish mine would turn off! Light stays on when brake off...push it down a tad and it goes off but go over a few bumps on the road and light comes back on... :bang:
Replied by David Aiketgate on topic Hand brake light
Posted 13 years 5 months ago #102957
There is a simple push button type switch attached to the handbrake.When the handbrake is lowered the lever pushes the switch down to knock off the light.
Flickering usually means that the handbrake cables need a little tightening. But check your brake fluid level too as the light also acts as low fluid warning.
No light could be the bulb, but it could also be the switch has jammed in the down position. This happened to me and when I investigated the switch's internal spring had collapsed.
You can see the switch by removing the gaiter.
Last Edit:13 years 5 months ago by David Aiketgate
Last edit: 13 years 5 months ago by David Aiketgate.
The following user(s) said Thank You: bryan young, sherwood0_8
Replied by bluelightmgf on topic Hand brake light
Posted 13 years 5 months ago #103033
Freeystyle i read a mod on the how to the other day telling you how to fix that problem. it looked very easy and no messing with the handbrake adjustment
The following user(s) said Thank You: Freestyle
Posted 13 years 5 months ago #103034
Replied by John and Sue on topic Hand brake light
Posted 13 years 5 months ago #103105
If the dash light isn't working you may not get low fluid warning. I'd test that the float operates the lamp. Ignition on, remove cap and float, check light comes on.
The following user(s) said Thank You: Freestyle, sherwood0_8
Posted 13 years 5 months ago #103136
bluelightmgf wrote: Freeystyle i read a mod on the how to the other day telling you how to fix that problem. it looked very easy and no messing with the handbrake adjustment
Cheers mate... Can you remember where? ;) I need to sort .. It's doing my head in :bang:
Tina
Posted 13 years 5 months ago #103137
David Aiketgate wrote: This one :shrug:
Very in depth how to... :broon:
Last Edit:13 years 5 months ago by Freestyle
Last edit: 13 years 5 months ago by Freestyle.
Replied by vale31 on topic Hand brake light
Posted 13 years 5 months ago #103145
had the same prob last wk,it the switch on the handbrake lever u can access it by removing the centre consel its held in position by screws loosen screws and the switch its self is ajustable moved mine up about 3 mil and it sorted it,also check your brake fluid level and top up,this makes light stay on also,hope that helps,paul...... just to had screws are pain to get at.good luck
by vale31
Posted 13 years 5 months ago #103157
Yep, good advice. :welcome2:
Replied by sherwood0_8 on topic Hand brake light
Posted 11 years 9 months ago #150974
Update!
On removing the hand brake gator today the switch had totally come off the handbrake mechanism and was wedged down the side of the tunnel after a lot of messing round trying to fish it out I got it re- attached and working and its only taken me
1 year 7 months to figure out and fix Naughty :spank: !!!!
Time to create page: 6.086 seconds
