Fitting a glass window
1. Where is the best place to get one?
2. Is it easy to fit?
3. Do thy come with heated elements?
Cheers
They are resonably easy to fit, unzip along the top, remove the rivets along the bottom and the plastic one is released, refitting is the reverse.
Supplirs include MGFmania, BAS international and IIRC a firm called MX5 something, sure there are others as well.
Main thing to check is the zip, there are 2 different types which are not compatable, in the worse case you'd have to change the fixed part of the zip.
a hard top.
The glass rear screen and a new roof are on my wish list along with sports pack and exhaust and leather seats and.......
- richandpaula
Heated rear elements are great and the best bit is no more unzipping the milky screen that's waiting to crack in cold weather, no more struggling with a zip that comes off it's carrier...You won't regret it.
fast jan wrote: I've got a BAS sportster hood and it's one of my best MG buys despite the car being parked in a garage and rarely suffering from frost etc. The viewing area is smaller than the normal plastic screen, but the clarity more than makes up for the size difference
Is the BAS sportster hood a complete hood and frame or do you have to fit it it to your existing frame?
If it has to be fitted to the existing frame, how difficult and time consuming is it?
