Fitting a glass window
  • Webby
  • Apprentice MGer
  • Apprentice MGer
Fitting a glass window was created by Webby
Posted 13 years 3 months ago #108157
I am looking to fit a glass window to the hood on my TF, before I do a few questions:-
1. Where is the best place to get one?
2. Is it easy to fit?
3. Do thy come with heated elements?
Cheers
by Webby
Replied by Tibs on topic Fitting a glass window
Posted 13 years 3 months ago #108163
Google MGFMania, they supply good ones along with details on how to fit, Peter is very helpful if you call him
by Tibs
Replied by talkingcars on topic Fitting a glass window
Posted 13 years 3 months ago #108172
I've not seen a glass rear screen without heater elements. The cars all came with the bulk of the wiring fitted so it would be short sighted of a supplier not to fit the elements.
They are resonably easy to fit, unzip along the top, remove the rivets along the bottom and the plastic one is released, refitting is the reverse.
Supplirs include MGFmania, BAS international and IIRC a firm called MX5 something, sure there are others as well.
Main thing to check is the zip, there are 2 different types which are not compatable, in the worse case you'd have to change the fixed part of the zip.
Replied by Bapa on topic Fitting a glass window
Posted 13 years 3 months ago #108323
If I can fit one, then anyone can! I would however suggest not starting two hours before dark, unless you've got someone prepared to hold a torch...
by Bapa
Posted 13 years 3 months ago #108348
or in wet windy and sometimes snowy march unless you have a secret weapon
a hard top.
  • Webby
  • Apprentice MGer
  • Apprentice MGer
Replied by Webby on topic Fitting a glass window
Posted 13 years 3 months ago #108350
Thanks for the replies. Is it actually worth all the effort?
by Webby
Posted 13 years 3 months ago #108352
when your old hood is looking tired, has a split and the rear screen is going yellow definatly.
Replied by sam47 on topic Fitting a glass window
Posted 13 years 3 months ago #108353
If you are like me and drive at weekends and when the weather is fair, then probably not. The glass screen is smaller but on the plus side is much clearer than the plastic screens. With the heated elements this should make those dark frosty/snowy mornings slightly more bearable.
The glass rear screen and a new roof are on my wish list along with sports pack and exhaust and leather seats and....... :yesnod:
by sam47
Replied by David Aiketgate on topic Fitting a glass window
Posted 13 years 3 months ago #108405
Apart from the obvious advantages of heated demist and clear view, you no longer have that uncertain feeling when you drop the top.ie will there be a heart rending 'Crack' as the plastic screen declares enough! :bang:
Replied by richandpaula on topic Fitting a glass window
Posted 13 years 3 months ago #108407
Definitely one of the best things we've had done to the car was to get ours fitted by MGF Mania at POL last year.
Heated rear elements are great and the best bit is no more unzipping the milky screen that's waiting to crack in cold weather, no more struggling with a zip that comes off it's carrier...You won't regret it.
Replied by fast jan on topic Fitting a glass window
Posted 13 years 3 months ago #108413
I've got a BAS sportster hood and it's one of my best MG buys despite the car being parked in a garage and rarely suffering from frost etc. The viewing area is smaller than the normal plastic screen, but the clarity more than makes up for the size difference :broon:
Replied by Fred on topic Fitting a glass window
Posted 13 years 3 months ago #108458
fast jan wrote: I've got a BAS sportster hood and it's one of my best MG buys despite the car being parked in a garage and rarely suffering from frost etc. The viewing area is smaller than the normal plastic screen, but the clarity more than makes up for the size difference :broon:
Is the BAS sportster hood a complete hood and frame or do you have to fit it it to your existing frame?
If it has to be fitted to the existing frame, how difficult and time consuming is it?
Last Edit:13 years 3 months ago by Fred
Last edit: 13 years 3 months ago by Fred.
Time to create page: 0.449 seconds
