Front Wheel Bearing
Hi folks, I am looking to change my front wheel bearings on my 2001 mgf and looking for any pointers including pictures. Can any one help. I have the new bearings, just need to fit them.
Cheers Lawrence
Cheers Lawrence
by Lar Adams
You'll need a hydraulic press to change the wheel bearings.It's not really a diy job, tbh. Taking the hubs off and visiting an engineering workshop is probably the cheapest option.
This is the process of fitting new bearings into a hub.
http://www.the-t-bar.com/en/forum/22-cjj-s-guides/89546-replacing-a-wheel-bearing#124269
Thanks guys, had the mgf for a couple of years and been lucky. Now time to get my hands dirty. I'm they are fun to work on.
by Lar Adams
Ok guys. First issue, I can't get the nut to come of the hub. Tried everything inc extension bars. There was a mention of a locking key but I cant see one. Any ideas great fully appreciated.
Lar
Lar
by Lar Adams
there isn't a locking key, instead the centre of the nut is hammered (staked) into the stub axle. You just tap it out using a punch and hammer. Doesn't matter if you damage it as it will be replaced as part of the hub kit.
I managed to press the bearing out with a 2 ton bottle jack and a frame made out of unistrut and a couple of large sockets. Then removed the centre of the bearing from the stub axle very carefully with an angle grinder.
Last Edit:12 years 11 months ago
by billd
Last edit: 12 years 11 months ago by billd.
Thanks mate, managed to remove the nut now. Just needed an even longer bar
by Lar Adams
Time to create page: 0.569 seconds
