mgf trophy 160 boiling problem thinking air lock
  • mick
  • Apprentice MGer
  • Apprentice MGer
mgf trophy 160 boiling problem thinking air lock was created by mick
Posted 12 years 1 day ago #146929
i have changed the head and everything ie gasket bolts water pump timing belts now got a boiling problem any ideas i have been told its an air lock and theres 3 points to bleed from ... i dont know where these points are can anyone help please ?
by mick
Replied by JanCo on topic mgf trophy 160 boiling problem thinking air lock
Posted 12 years 1 day ago #146931
First one is on the top of the radiator, right hand side as you're looking at it. Second one need you to remove the front bay plastic cover, that sits just behind the brake servo. You'll see a bleed nipple coming out of more or less the middle of the bulkhead.
The third one is hardest to get at but not impossible. Lift the inspection cover and it's on the metal pipe on the nearside of the engine. On mine at least it's just an M5 bolt, so an 8mm spanner or socket. I found a 1/4" drive ratchet & a long extension made it easy to access.
HTH
by JanCo
  • mick
  • Apprentice MGer
  • Apprentice MGer
Replied by mick on topic mgf trophy 160 boiling problem thinking air lock
Posted 12 years 1 day ago #146932
thankyou very much for your help i will try that .. cheers mick
by mick
Replied by Badger on topic mgf trophy 160 boiling problem thinking air lock
Posted 12 years 1 day ago #146933
Make sure the auto bleed valve is working, it's inside the inlet manifold where the small coolant hose fits from the top of the header tank.
If you remove the small hose at the top of the expansion tank you should be able to blow down it (with resistance as there is a small ball valve to restrict the flow but this allows air in the system to escape to the highest point.
Other thing to check is if the thermostat is opening!
Brian.
by Badger
Replied by bryan young on topic mgf trophy 160 boiling problem thinking air lock
Posted 12 years 1 day ago #146935
Also Bleed the Heater (centre one) with the control to full hot, keep the expansion bottle full whilst bleeding. important to check the 'jiggle valve'' in the manifold too (did you check this when the manifold was off??
Finally replace the cap on the expansion bottle, these are notorious for failing and causing boiling.
  • mick
  • Apprentice MGer
  • Apprentice MGer
Posted 12 years 11 hours ago #146967
whats the jiggle valve ?
by mick
Replied by David Aiketgate on topic mgf trophy 160 boiling problem thinking air lock
Posted 12 years 10 hours ago #146968
aka the auto bleed valve as described by Brian in post above. :yesnod:
  • mick
  • Apprentice MGer
  • Apprentice MGer
Posted 12 years 8 hours ago #146970
ive done all 3 and ts still boiling but everything is circulating now ... the valves were not done when the manifold was off was off no . i am again at a loss ?
by mick
  • mick
  • Apprentice MGer
  • Apprentice MGer
Posted 12 years 8 hours ago #146971
sorry the valves were done while the manifold was off yes ... misunderstanding there sorry
by mick
Posted 12 years 7 hours ago #146972
Take it logically. Get a new expansion tank cap, an OEM spec one(flat black with brass fittings inside)
Air in the system tends to create a rising tank level rather than bubbling.
Boiling is usually associated with a failed pressure cap. The cap maintains a +1 bar pressure in the system, this raises the boiling point of the coolant.
If the coolant is boiling it's likely that the pressure is not being maintained, so try the pressure cap first.
Last Edit:12 years 7 hours ago by David Aiketgate
Last edit: 12 years 7 hours ago by David Aiketgate.
  • mick
  • Apprentice MGer
  • Apprentice MGer
Posted 12 years 7 hours ago #146974
ive taken a video of it boiling but i am struggling to upload it ... i will order a new cap tomorrow and try that ... working silly hours but got thursday off so al be at it again then ... i think its boiling my head never mind the car ... i should have left it to the scrap yard instead of doing a rescue lol
by mick
Time to create page: 0.423 seconds
