Door Check Strap
Door Check Strap was created by steverfc
Posted 10 years 2 months ago #152677
Hi, does anyone know of a fix for a broken door check strap mounting on my 2005 TF. The bracket that secures the strap inside the door pillar has broken free and I can't see an easy option to refix it. Any ideas ?
Replied by talkingcars on topic Door Check Strap
Posted 10 years 2 months ago #152679
I suspect the bracket is welded in place. Is it possible to rivet or bolt it in place?
Replied by Leigh Ping on topic Door Check Strap
Posted 10 years 2 months ago #152681
steverfc wrote: Hi, does anyone know of a fix for a broken door check strap mounting on my 2005 TF. The bracket that secures the strap inside the door pillar has broken free and I can't see an easy option to refix it. Any ideas ?
:welcome: Steve. Pics might help our members to diagnose a fix for you. Got a camera / phone handy?
Replied by GT MG SPARES LTD on topic Door Check Strap
Posted 10 years 2 months ago #152685
Tap out the locating dowel that attaches it to door post.
Remove door card make sure your glass window is in the up position.
Two bolts visible on the external side of restrictor 10mm hold the restrictor in place undo them and you can remove the restrictor from inside the door, hence remove door card.If it cant be fixed replace it.
Posted 10 years 2 months ago #152695
Good advice except it's the car end that has failed.
Posted 10 years 2 months ago #152701
Never saw it break inside the A post before,Wondering if its possible to get a look in there with the glovebox out.
Replied by steverfc on topic Door Check Strap
Posted 10 years 2 months ago #152705
Thank you for the responses. I have added a photograph which shows the bracket inside the door pillar protruding through the hole in the pillar. It is the offside check strap and I cannot see anywhere where I can get access to get it re-fitted !
Last Edit:10 years 2 months ago by steverfc
Last edit: 10 years 2 months ago by David Aiketgate.
Time to create page: 0.544 seconds
