Renew Alternator Bosch
Renew Alternator Bosch was created by verplant23
Posted 10 years 1 month ago #153228
First sorry for my bad english but i´ll try my best.
i only made pics of assembling the alternator. Disassembling is always a easy game ;)
Parts needed
4x M4x18 kopf d7,9
4x M5x60
3x M5x20
3x washer M5
2x M4x20
Bearing 6003 17x35x10 mm 2RS class C3
Bearing 6303 17x47x14 mm 2RS class C3
Collectorcover
Regulator Bosch also used by some Hondas
BOSCH F00M145206
BOSCH F00M145240
>BOSCH F00M145269< MGTF Rover ones
BOSCH F00M145346
BOSCH F00M145389
BOSCH F00MA45213
BOSCH F00MA45238
BOSCH FOOM145206
Alternator numbers also uses this regulator
BOSCH
0124325006 0124325007
HONDA
31100PDAE01
PIC
2205118 2205119
0124225039 BOSCH
0124225042 BOSCH
0124325006 BOSCH
0124325007 BOSCH
0124515020 BOSCH
0124515021 BOSCH
0124225010 BOSCH
0124225011 BOSCH
diodeplate F00M144002
diode diameter 12,8mm
collector for bosch alternator 0124 and 0123
all parts can be bought here http://www.lima-shop.de/en/ but also somewhere cheaper ;) like bearing and the regulator i bought somewhere else.
While disassembling the alternator the only tricky part is by disconnecting the collector. do not damage the copper contatcs. after disconnecting the collector you have to mill out the collector.
after cleaning everything especially the bearing housing and the shaft assembling is like a kids puzzle.
in my example the diods were ok so no need to change. the regulator was damaged. so u have to check your diods with ohm meter. it has to show something around 0.4-0,7 ohms in one direction.
Last Edit:10 years 1 month ago by verplant23
Last edit: 10 years 1 month ago by David Aiketgate.
Replied by verplant23 on topic Renew Alternator Bosch
Posted 10 years 1 month ago #153229
Last edit: 10 years 1 month ago by David Aiketgate. Reason: clicked insert
Posted 10 years 1 month ago #153231
Posted 10 years 1 month ago #153232
Replied by David Aiketgate on topic Renew Alternator Bosch
Posted 10 years 1 month ago #153233
:welcome2: Amazing first posts! :yesnod: :broon:
Posted 10 years 1 month ago #153234
learned so much from you guys just giving something little back. ;)
changed cambelt alternator belt water pump oil pump and fitted my sump baffle this weekend. everything went good with your help ;) so i thought about posting this little how to.
new alternator = lots of money
new regulator = 24€
The following user(s) said Thank You: David Aiketgate, talkingcars
Replied by talkingcars on topic Renew Alternator Bosch
Posted 10 years 1 month ago #153235
Welcome to the forum
I think this wins the prize for best first post.
James
Time to create page: 0.602 seconds
