Drain fuel tank .fill with new petrol
Need to drain fuel tank .not possible to syphon .need to fit pipe to filter and drain from there
Is it just switch on ign .or is there a run only relay
Last Edit:6 years 3 months ago
by Fiddler
Last edit: 6 years 3 months ago by Fiddler. Reason: Relay
If you are planning to use the fuel pump to drain the tank, be aware that if it runs dry, the pump will likely be destroyed!
by G0RSQ
Replied by Cobber on topic Drain fuel tank .fill with new petrol
Posted 6 years 3 months ago #192917
Just put a long length of fuel hose with a siphon pump from the fuel line to a big enough container on the floor.
I always use the priming bulb from an old outboard motor as a siphon pump........been using the same one for over 30 yrs, works a treat!
Last edit: 6 years 3 months ago by Cobber.
Replied by Fiddler on topic Drain fuel tank .fill with new petrol
Posted 6 years 3 months ago #192919
Found relay .pipe has easy connector from fuel filter 8mm pipe to container .just not run pump dry . Fill new petrol .
Easy thanks .
Easy thanks .
by Fiddler
Posted 6 years 3 months ago #192936
No ,didn't bother .got 8 litres out to almost empty just by ign on batt switch on/ off a few times . Found a large black big 2 socket relay behind ECU . Looked at it and put back .
Changed oil and filter .Almost forgot fill engine via cam cover filler .Eng cover is .. off. Very slow via filler at rear + dipstick .
Battery CLP to put back . Stupid place for clamp. Might pass MOT check for brakes and glass analysis . Fresh petrol will help.
by Fiddler
Posted 6 years 3 months ago #192937
CLAMP AND GAS ! THICK FINGERS
by Fiddler
Time to create page: 6.802 seconds
