Steering column
Replied by Airportable on topic Steering column
Posted 1 year 6 months ago #210756
The bending down doesn’t create the problem, it the return to the upright which underscores the aged.
I have bending down jobs to do, procrastination is getting in the way; that & the cold garage.
Last Edit:1 year 6 months ago by Airportable
Last edit: 1 year 6 months ago by Airportable. Reason: Spell check had replaced “procrastination” with “procreation”, now there’s a memory!
Replied by talkingcars on topic Steering column
Posted 1 year 5 months ago #210882
Oh my giddy aunt.
yes my car is 1999 and it does have the adjust
lever mechanism.
I am not driving at the moment due to illness. My son is going to have a look at the car for
me. Are/is everything accessible or does he need to dismantle the dash?
Wishing you a speedy recovery.
The bolts on the adjustable column are further apart than the bolts on the non adjustable earlier column.
How did the installer get around this?
It sounds like they didn't do a very effective job.
The bracket should have been welded to the cross bar that lives under the dash.
You (or your son) should be able to access the mounting point by removing the speedo.
Also did they change the wiring and the ECU to the later version?
Time to create page: 0.375 seconds
