Dials have arrived
Dials have arrived was created by pendle lass
Posted 12 years 9 months ago #39661
Mr Postman delivered these today, when back lit they will be blue to match my clock and oil guage... Not ordered anything else for the project yet and I get a feeling this is not going to be as easy as peeps make out. I need to inspire Daz :(
BUT once this is done there's not much more needed for my little car, I suppose that could be an incentive for him. I know some of you have dabbled David & Mark so any help would be great but please keep it simple for me you know Im easily confused.
I have there now but they are rubbish at night with being front lit with blue bulbs
Last Edit:12 years 9 months ago by pendle lass
Last edit: 12 years 9 months ago by pendle lass.
Replied by Leigh Ping on topic Re: Dials have arrived
Posted 12 years 9 months ago #39664
Courtesy of David A - Plasma Dials - Fitting guide.
Looks a mission to be brutally honest. :unsure:
Last Edit:12 years 9 months ago by Leigh Ping
Last edit: 12 years 9 months ago by Leigh Ping.
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic Re: Dials have arrived
Posted 12 years 9 months ago #39665
I want some, Where'd they come from?
Last Edit:12 years 9 months ago by psymon
Last edit: 12 years 9 months ago by psymon.
Replied by pendle lass on topic Re: Dials have arrived
Posted 12 years 9 months ago #39666
Thanks Leigh, getting the unit out and the needle off etc is the easy bit, these arent plasma so a bit different
the confusing bit will be the LED placement to get an even spread and the illuminating needs and wiring it all up to work.
I do have a spare cluster to practice on so not gonna be exactly stuck so I wont say it'll be done over night just think we need to get everything, be in the right frame of mind and have the time
Posted 12 years 9 months ago #39667
Psymon wrote: I want some, Where'd they come from?
from Naomi, I have the heater panel, clock and oil guage and they look really good
http://www.metal-monkey.co.uk/acatalog/Rover.html
  • psymon
Posted 12 years 9 months ago #39668
You could get the Plasma Dials Unprinted. or get some Electroluminescent Panels which you can cut down to shape to go directly behind the dials. Wouldn't have worry about LED placement then. At least that would be my plan
Here's an one http://proto-pic.co.uk/white-electroluminescent-el-panel/
Mark may be able to advise if this would work, Thinking it would also mean an easier way of passing light through to needles as well
Posted 12 years 9 months ago #39669
Psymon wrote: You could get the Plasma Dials Unprinted. or get some Electroluminescent Panels which you can cut down to shape to go directly behind the dials. Wouldn't have worry about LED placement then. At least that would be my plan
that would certainly be alot easier :yesnod:
Replied by rayb on topic Re: Dials have arrived
Posted 12 years 9 months ago #39677
speak to mark ,when i was over at his house he showed me one he had done for somebody that was backlit, carnt remember what sort of leds he used but it looked stunning.
by rayb
Replied by David Aiketgate on topic Re: Dials have arrived
Posted 12 years 9 months ago #39679
I have seen a set with the el panel behind and it works very effectively. :yesnod:
Posted 12 years 9 months ago #39701
David Aiketgate wrote: I have seen a set with the el panel behind and it works very effectively. :yesnod:
might order one then and have a play
Replied by Red Devil on topic Re: Dials have arrived
Posted 12 years 9 months ago #39703
They look great. :broon:
I love the Black dials that are fitted to my 85 :)
Last Edit:12 years 9 months ago by Red Devil
Last edit: 12 years 9 months ago by Red Devil.
Replied by MGF MARK on topic Re: Dials have arrived
Posted 12 years 9 months ago #39766
those el panels are quite good but i dont know if the brightness will be enough but this depends on personal choice ect
might be worth a play as would be cheaper than the led version i did
here is the iluminated pointer version however the front of the dash was put on just to show effect :)
mad about cars and bikes :)
The following user(s) said Thank You: Leigh Ping, Red Devil
Time to create page: 0.558 seconds
