Heater always hot?
Heater always hot? was created by bensewell
Posted 12 years 9 months ago #40388
Got the 04 TF two days ago was driving around and getting headaches, turned out that although the heat knob is on low it really is high? Strange..
Anyone know what is broken that i need to fix? I can see a trip to the scrap yard / eBay imminent.
Replied by bensewell on topic Re: Heater always hot?
Posted 12 years 9 months ago #40397
Will try this by CJJ on another site first and see how i get on.
http://forums.mg-rover.org/showthread.php?t=320810
Replied by Laz1957 on topic Re: Heater always hot?
Posted 12 years 9 months ago #40408
That looks like the best place to start :yesnod:
Shouldn't a copy of this be in our 'how to' section?
by Laz1957
Replied by bryan young on topic Re: Heater always hot?
Posted 12 years 9 months ago #40432
Laz1957 wrote: That looks like the best place to start :yesnod:
I thought that "how to" was on here already, as i have read it when the same problem came up before ~ :nonod: :yesnod: :nonod: I will ask Clive or David to pick it up from .org (shudder) and put it here. I even looked in the cjj guides section and it aint there either :bust:
Replied by MGF MARK on topic Re: Heater always hot?
Posted 12 years 9 months ago #40435
what clives missed one quick every one get it done :bust:
mad about cars and bikes :)
Posted 12 years 5 months ago #54515
A blast from the past but my heater is still on full whack going to try and fix or change the valve if I fix it a how to might follow
Replied by David Aiketgate on topic Re: Heater always hot?
Posted 12 years 5 months ago #54550
Have you checked that the cable is actually moving the valve? sometimes the metal lever gets dislocated from the plastic part and although the metal lever is moving it's not actually moving the valve.
Easily fixed by relocating the lever.
Posted 12 years 5 months ago #54569
I think it is doing so got a spare valve on the f if its not working
Posted 12 years 3 months ago #60356
Adjusted the cable but no joy so going to put swap the valve
Replied by John and Sue on topic Re: Heater always hot?
Posted 12 years 3 months ago #60370
Alla full-on heater can really be is the levers not operating the valves correctly or the valve internals are shot. I would test the replacement valve carefully before fitting!!
Posted 12 years 3 months ago #61053
So heres my adjustment. I moved the cable up to pull more of the cable and still...
Felling HOT HOT HOT
Posted 12 years 3 months ago #63018
I know this won't help you, as judging from your photo the valve is in the 'closed' position but my heater got stuck on the last day of our Italy trip.
On investigation, I found that the cable sleeve had come out of the clip at the center console end. There is a small 2 cable clip that holds this end (even though there is only 1 cable).
Here's a pic showing the cable clip to the valve on the right and the end from the center console on the left:
And here is a close up of the left hand clip (sorry it's a bit fuzzy):
Just a bit more info that may help someone in the future ;)
by Laz1957
Time to create page: 0.550 seconds
