Port Forwarding
Had to change it back.
http://www.kingdisplay.net/Security/IP-System-Knowledge/303.html
Psymon wrote: You need forward both the TCP and UDP. On the CCTV they are on different port numbers, so your nat rule should translate both ports.
I did try that, but it made no difference.
I will try making 2 rules. One for each.
I set the CCTV to DNS and restarted the hub. Deselected DNS and setup the extra port.
Now, as long as I don't reboot the router I will be OK as I'm not on a static ip.
Thanks for your help guys.
