engine indicator light
engine indicator light was created by sam47
Posted 11 years 8 months ago #105401
morning peeps
advice please. The TF has been idle in the garage for two weeks after replacing the battery. Took her for a little run this morning before going to the garage for an MOT.
The engine Indicator lamp remains on after starting up. Is this anything to worry about? :-?
by sam47
Replied by pendle lass on topic engine indicator light
Posted 11 years 8 months ago #105403
mine has a habit if coming on when its been stood or if i use a different petrol station
id get the code read someone near you Will have a reader or we can do it on the next run
Replied by paulsmgf on topic engine indicator light
Posted 11 years 8 months ago #105404
Some cars are susceptible to bring on the warning light if the battery charge is low so it might just bethat its been sitting draining to below the 12v dc
Replied by cjmillsnun on topic engine indicator light
Posted 11 years 8 months ago #105406
It is something to worry about, because the light could indicate a failure that will effect the emissions reading.
It may be worth getting the code read before taking it for test. Hopefully it will be a voltage related fault, which will be cured by a good run.
Replied by sam47 on topic engine indicator light
Posted 11 years 8 months ago #105407
Thanks Guys, yea could be when swopping old battery for new and the minutes inbetween when no power at all. Think I will take her for a blast up the spine road before the MOT. Might take up your offer with the reader, think the next run is the 24th March.
by sam47
Posted 11 years 8 months ago #105424
Woohoo Maggie passed her mot today. Engine light no longer illuminated.
by sam47
Replied by David Aiketgate on topic engine indicator light
Posted 11 years 8 months ago #105441
Replied by helsbyman on topic engine indicator light
Posted 11 years 8 months ago #105443
By the way Dave hope you get better soon [ is it hot in all them bandagers ]
Posted 11 years 8 months ago #105444
Oh you have changed it Ha ha
Posted 11 years 8 months ago #105445
Thought it was time to broadcast, 'why the bandages?' in case people mised my shoutbox confession.:yesnod:
Posted 11 years 8 months ago #105448
pendle lass wrote: mine has a habit if coming on when its been stood or if i use a different petrol station
I had a lot of trouble with my light but since useing shell all the time the problem has gone also my cam belts were loose
Posted 11 years 8 months ago #105450
David Aiketgate wrote:
Brilliant :yesnod:
by sam47
Time to create page: 0.530 seconds
