Glass mike satur wind braker?
- sherwood0_8
Will a Mike Satur glass wind braker fit with MK1 X power hoops ? also can I fit a glass screen in my soft top with the said hoops?
by sherwood0_8
I'm pretty sure the Mk1 xpower hoops are the ones that slant forward that I had on the car when I first bought it, in which case no is the answer I'm afraid - the main support body for the hoops sits on the parcel shelf and takes up the room needed for a glass screen to lay flat (certainly a BAS hood, not 100% sure if other glass screens are a different size). the only wind stop I know that can be fitted with those hoops is a mesh one - but it can't be adjusted or lowered.
This is how the xpower hoops sit on the shelf:
You can see they lean too far forward to mount a windstop on the Tbar:
Last Edit:11 years 8 months ago
by fast jan
Last edit: 11 years 8 months ago by fast jan.
The following user(s) said Thank You: David Aiketgate, sherwood0_8
Time to create page: 0.551 seconds
