F rear track control arm
Took my rear hub off weekend to replace noisy rear bearing.
I noticed the rear track control arm is very sloppy at the bush end (its the arm at the rear of the hub with a ball joint one end).
Just wondered how sloppy this is meant to be? As it appears you can only buy a complete arm and they are around £80.
by coxy134
- Diesel Destroyer
You can buy the hub end.. If its the subframe end then its a case of buy new..
I've got to buy a pair of brand new ones
Someone on here had a link to the right hub end,,, rover 200 if I remember correctly
Thanx for info but how sloppy should it be or should the bush end be quite stiff?
by coxy134
You should be able to move the arm up and down with a little effort. It should not flop about or move rotationally.
The following user(s) said Thank You: coxy134
Time to create page: 1.220 seconds
