MGF LEATHER SEATS
MGF LEATHER SEATS was created by sherwood0_8
Posted 11 years 7 months ago #112853
Hello a trip to my local scrap yard today was very nice with a new smashed up MGF with mint leather seats that I got for a good deal along with door leathers and arm rest, I stripped them out and I am picking them up in the morning.
Now the question is as the car I got my new goodies out of was a MK2 F will I have to change the seat belt tensioners as it was fitted with TF style seats ?
if I do have to change is it a easy swap?
Cant wait to get my tan cream seats fitted to the old girl :woohoo:
Replied by highflyer1000 on topic MGF LEATHER SEATS
Posted 11 years 7 months ago #112856
hi
good find .
just check the colour of the seat plugs from the carpet area if yours are yelow and the pre tensioner plugs are yellow your ok, same for red if they are different colours just put your pretensioners on the new seats
its just 1 bolt holding them on so easy job , just dont dismantle the tube or wiring from them
Paul D
Last Edit:11 years 7 months ago by highflyer1000
Last edit: 11 years 7 months ago by highflyer1000.
The following user(s) said Thank You: sherwood0_8
Replied by bensewell on topic MGF LEATHER SEATS
Posted 11 years 7 months ago #112857
ITs easy mate just a few TORX bolts. 4 on the seat frame one on the seat belt. Don't pull any wires too hard and take your time. I did 2 seats and a full interior in 2 hrs
Replied by sherwood0_8 on topic MGF LEATHER SEATS
Posted 11 years 7 months ago #112876
Thank you guy's do the wires run inside the bottom of the seat ???????? are they hard to get at?
Posted 11 years 7 months ago #112880
no best way i found was pull seat forward, undo 2 back bolts.
pull seat back undo 2 front seat bolts
then lift the seat up a little bit and wedge a bit of wood under it then yoy can undo the srs cable, its held on with a tie wrap lug thing.
then while seat it on the wedge of some kind undo seat belt bolt
then finally the lot comes off in one go so eat your spinach and lift the seat out
easy peasy lemon squeezy
Posted 11 years 7 months ago #112884
oh forgot to add srs cable / connector just pulls apart i slipped a pairing knife in the gap then wiggled with small flat blade screw driver then it came away easy
Posted 11 years 7 months ago #112891
Thats great thanks I just had a look on my car and the SRS plug is red and the one on the seats I stripped out is also red so should be easy !
Next question if any one can help me?
The seats I am putting in from the scrap yard came off a car that the air bag had gone off on, so even tho my plugs are both red will I still need to change the pre tensioners????? would this have gone off with the air bag??? what about the passanger side will that need changing???
Replied by David Aiketgate on topic MGF LEATHER SEATS
Posted 11 years 7 months ago #112897
I think they all fire together, so use yours!
Posted 11 years 7 months ago #112907
yeah use yours to be safe or your srs light will be on.
Posted 11 years 7 months ago #112909
cheers :beer:
Posted 11 years 7 months ago #112914
if it goes wrong let me know i have a full srs wiring loom, tensioners & other its in my hoarding pile in the garage
Time to create page: 0.549 seconds
