REAR FOG GUARD LAMPS NOT WORKING
- Smoothyman
- Apprentice MGer
- bryan young
Replied by bryan young on topic REAR FOG GUARD LAMPS NOT WORKING
Posted 11 years 7 months ago #114757Smoothyman wrote: Just need advise on this. 2005 TF 115. Light on switch does not illuminate. With engine on, H/L' on, no rear fog guard lamps. Fuses check and fine. Bulbs are healthy. There is power to the switch. Would assume switch faulty however could fault exist further back in system? Maybe ECU. Anyone with similar experiences? Look forward to hearing from you. Cheers.
Could be a break in the wiring from the boot lid or a bad earth. Have you got power at the bulb holder. Rear fogs will only work with headlamps on dipped beam. have you taken fuses out and checked them with a tester? :oops:
- Smoothyman
- Apprentice MGer
Replied by Smoothyman on topic REAR FOG GUARD LAMPS NOT WORKING
Posted 11 years 7 months ago #114771Please Log in or Create an account to join the conversation.
Here is a list of control relays in the Pektron SCU:
Rear Fog Lights
Electric Window (drivers side only)
Central Locking/Superlocking
Windscreen Intermittent Wipe
Windscreen Washers
Horn.
There is a good write-up from Technozen at MG-Rover.org from this link: http://forums.mg-rover.org/showthread.php?t=384938
- bryan young
Posted 11 years 7 months ago #115178Badger wrote: If your boot loom wiring is OK then it could be a failed relay; on your 05 model it has the Pektron SCU (round alarm key fob) One of the control relays for the rear fogs is in the SCU module; it’s a dual relay shared by the horns.
Rear Fog Lights
Windscreen Washers
Horn.
One of our club members had the BCU (body control Unit) replaced because locking and horns not working and failed MoT Refurbished unit by Technozen and all ok now This was on an April 2005 TF Spark
- Smoothyman
- Apprentice MGer
Posted 11 years 7 months ago #115341Please Log in or Create an account to join the conversation.
Regards,
Andy
- John and Sue
Replied by John and Sue on topic REAR FOG GUARD LAMPS NOT WORKING
Posted 11 years 7 months ago #115365It will be all right in the end. If it isn't all right yet, then it is not yet the end..
Hey ho....
Regards,
Andy
- Smoothyman
- Apprentice MGer
Replied by Smoothyman on topic REAR FOG GUARD LAMPS NOT WORKING UPDATE
Posted 11 years 6 months ago #119349Also toying with the idea of changing the exhaust box to something a little more fruity without going over the top. Local chums seem to think Scorpion is the unit to go for.
Regards to all.
- Smoothyman
- Apprentice MGer
Posted 11 years 5 months ago #120984Please Log in or Create an account to join the conversation.
