Shortening the gearstick?
I bought a tap & die set to do our 02 TF when we had that rethreading is not needed for this one but would like to shorten it by 25mm at least?
TIA
- John and Sue
Re threading the lever is usually a mare due to the taper below the threaded portion and the fact they're usually quite hard.
- Diesel Destroyer
- Tourbillon
I carried out this mod to, however my gear knob is a aftermarket with a clamping mechanism with a couple of concealed screws so didn't have to worry about tapping a thread on. Knob is now right down to the gaiter and very positive to use.
- mgf bushdevil
- Journeyman MGer
Good luck with yours :broon:
- richandpaula
- Tourbillon
I swear that the adjustment bolts on mine were a mix of imperial and metric as I could only get an imperial spanner to fit on one....
On our previous 02 TF I cut 25mm or 1" in old money off the shaft & threaded the shaft further down which wasn't right hard but I can't even get the knob off this one?
- John and Sue
However, I bought the Rickbrook knob with the MG logo on and did as John has, I counter bored it deeper by around a further 10mm using a drill fractionally larger than the shaft diameter to ensure a tight fit at the top. I still had to run some insulating tape further down to ensure it still sat tight. If you are not worried about returning it to original yu can cut the shaft. I seem to recall the late David C with the orange LE500 did this on his, not sure if I read about it here or .org.
