My F keeps blowing fuses.
My F keeps blowing fuses. was created by Shutts
Posted 11 years 5 months ago #121263
Help please.
My F (MY2000) keeps blowing fuses 12 & 16 (clock, radio & interior lights + Stop & Reversing lights).
I thought I had it all sorted this morning when only fuse 12 wasn't playing ball - fixed I thought.
Then this afternoon fuse 16 joined in. :bang:
I did notice that after I had allegedly 'repaired the radio etc' the brake lights came on on their own. Opened the boot lid and they went out.
What is going on?
Any help greatly appreciated.
Cheers,
Shutts
Some days you are the pigeon and some days you are the statue.
by Shutts
  • Visitor
  • Visitor
Replied by a Guest on topic My F keeps blowing fuses.
Posted 11 years 5 months ago #121265
fuse 12 and 16 are unrelated curcit wise,excuse spelling famous for it.it could be a bad earth on the rear of the car.
radio fuse. the leads are long behind the unit so you can pull it out and replace it.the wires can be sorting somewhere.
the earth is on each inner wing behind each rear lamp.unbolt and clean and rebolt.check that the plugs are dry and clean on the lamps.
Replied by cjj on topic My F keeps blowing fuses.
Posted 11 years 5 months ago #121268
Have you checked the loom on the nearside boot hinge?
The following user(s) said Thank You: Shutts
Replied by Shutts on topic My F keeps blowing fuses.
Posted 11 years 5 months ago #121269
Many thanks boys. I'll check there first.
Further update later in the week.
Thanks again
Shutts :beer:
by Shutts
Posted 11 years 5 months ago #121354
Result. :woohoo:
Thanks Darren. Removed radio and refitted. All now working properly.
Thanks Clive. Checked wiring loom by the boot hinge and it fell apart. All wires broken
At least I've got something to do at the week-end.
Well played boys you are both stars.
Virtual beers all round. :beer:
Cheers,
Shutts
by Shutts
Posted 11 years 5 months ago #121360
Result. :broon:
Try and introduce a bit of extra cable when you repair it to give some slack and maybe a bit of spiral wrap to add protection.
Posted 11 years 5 months ago #121361
Many thanks.
Will do.
Do you recommend any particular method of joining the cable?
If I remember you don't approve of scotchlocks.
Thanks again.
Shutts
by Shutts
Posted 11 years 5 months ago #121365
Daryl apologies for calling you Darren :spank:
by Shutts
  • Visitor
  • Visitor
Posted 11 years 5 months ago #121366
the favorite issue is the clock wire often earths and causes the fuse to blow.any way at least its a job now fixed.no worries about the name
Replied by John and Sue on topic My F keeps blowing fuses.
Posted 11 years 5 months ago #121372
Shutts wrote: Many thanks.
Will do.
Thanks again.
Shutts
Chiming in late to this, I'd recommend soldered joints and heat shrink for splicing in new cables. Definitely not scotchloks. Should be against the effin law.
In line crimps are effective but are bulky and untidy IMO.
Glad you found the faults. :broon:
Replied by Shutts on topic Re:My F keeps blowing fuses.
Posted 11 years 5 months ago #121387
Many thanks. I'll go the solder and heat shrink route.
by Shutts
Replied by Tourbillon on topic Re:My F keeps blowing fuses.
Posted 11 years 5 months ago #121428
Shutts
Extra wire, solder and heat shrink is the way to go. Also leave off the lower clip on the boot lid as this forces the wiring in a tight curve.
TB
Last Edit:11 years 5 months ago by Tourbillon
Last edit: 11 years 5 months ago by Tourbillon.
Time to create page: 0.534 seconds
