Help with Workshop Companion
Morning!
Downloaded and installed the Workshop Companion, however when I select an item from the Workshop list on the left, no file is being opened in the main screen.
I have downloaded the MGTF Workshop manual and K-Series manual, I have put both .pdf files in the DB folder of Workshop Companion.
:bang:
:bang:
by SMGITHY75
Replied by David Aiketgate on topic Help with Workshop Companion
Posted 11 years 4 months ago #123963
One for Simon, the companion's creator. I'll notify him. :yesnod:
The workshop list is for recording and keeping track of your own work, you'd select the part of the car you are working on and then click 'Add New Job button' , fill in the details and your done
by psymon
:doh:
That will be that then, sorry I thought it worked like the "How to" Selection.
Problem solved!
Cheers Psymon
Problem solved!
Cheers Psymon
by SMGITHY75
i had to download and install it earlier, so it should be working, got it via the downloads item on the community menu.
by psymon
The following user(s) said Thank You: John Pell
Time to create page: 1.658 seconds
