cam gasket
I have an oil leak on my cam cover so a new gasket will be got BUT I have a TF160 [vvc ] now some ebay ads say any MGF/TF cam gasket will fit all, others say not V V C so is there a gasket just for the V V C
THANKS
THANKS
by helsbyman
AFAIK they are all the same.
Worth getting one from a reputable source to avoid the cheap painted version.
The following user(s) said Thank You: helsbyman
- Tourbillon
I will second that after my Cam cover gasket de-laminated into the top of the engine.... the proper one has a rubberised coating not a hard painted finish.
by Tourbillon
Thanks for your replys I well get one from Rimmer's
by helsbyman
Hi, is the OEM gasket rubberised as there is one on ebay £7 and it's made with the same material as the OEM gasket so the seller says
Last Edit:11 years 3 months ago
by helsbyman
Last edit: 11 years 3 months ago by helsbyman.
OEM has a 'rubber' coating. :yesnod:
Thanks David. £7 is a bit cheaper than rimmer and free p/p
by helsbyman
Time to create page: 0.502 seconds
