Servo brace bracket
Servo brace bracket was created by Forrester
Posted 11 years 2 months ago #126972
After recent posts on this topic, it seemed a very good mod. to do on my F.
Took the big black cover off to see what sort of bracket I could codge up & to my surprise saw that there was one already fitted ;)
It looks like an OEM fitting.
Have other F's got this fitted?
Replied by Badger on topic Servo brace bracket
Posted 11 years 2 months ago #126976
Looking at your image there is no extra brace fitted, it would be mounted between the double skin flange under your heater uptake snorkel and connect to the top left servo bolt.
by Badger
Replied by Diesel Destroyer on topic Servo brace bracket
Posted 11 years 2 months ago #126978
Where? :-?
Replied by Forrester on topic Servo brace bracket
Posted 11 years 2 months ago #126981
That's the point I'm making. Does it need more support than already fitted. ;)
I feel the braking feel still needs better reaction especially from high speed.
Replied by Rich in Vancouver on topic Servo brace bracket
Posted 11 years 2 months ago #126985
There is a lot of flex in the bulkhead that the servo is mounted on and any extra support is a good thing. Here is a pic of one type of bracket (The "Jaylad" bracket) shown with a TF Snorkel.(This bracket will not mount with a Mk1 MGF air intake)
Note: you get better results mounting the bracket on the master cylinder rather than on the spare tyre!
Last Edit:11 years 2 months ago by Rich in Vancouver
Last edit: 11 years 2 months ago by Rich in Vancouver.
Replied by Whiz on topic Servo brace bracket
Posted 11 years 2 months ago #126990
Forrester, i think, from what I have read on other threads, the flex doesnt come from the bracket itself (which yes, i guess all servos look like yours ;)) but where its mounted against that piece of bodywork, its that that bends.
So the brackets effectively attach the servo to a more sturdy bit of the body.
I may be completely wrong however. :)
by Whiz
Replied by cairnsys on topic Servo brace bracket
Posted 11 years 2 months ago #126995
Forester, there's an excellent How To from cjj on this topic.
http://www.the-t-bar.com/en/forum/22-cjj-s-guides/75834-brake-servo-flex-fix
I've just made one up for my F using a slightly different approach to others but I can say that it definitely improves the braking!
Adam is right, it's the flex in the bulkhead that the servo bracket is mounted to that's the problem.
This is an easy to do fix that has big benefits.
Robin
The following user(s) said Thank You: Forrester
Replied by David Aiketgate on topic Servo brace bracket
Posted 11 years 2 months ago #126998
Where the flex occurs, and a simple brace.
The following user(s) said Thank You: Forrester, Yellow Peril
Replied by Davem on topic Servo brace bracket
Posted 11 years 2 months ago #127117
:broon:
[IMG]ht[/img]
by Davem
Replied by talkingcars on topic Servo brace bracket
Posted 11 years 2 months ago #127118
Nice one - I think the brace featured in Rich's post above benefits from the vertical strip along the back but doesn't look as good as a result.
Posted 11 years 2 months ago #127315
Got 2 brackets made by a mate who has an arc welder.
Fitted them today & it has made the brake pedal feel more solid :yesnod:
Had to cut 2 holes in the heater air box to fit them. Will this cause any problems?
Last Edit:11 years 2 months ago by Forrester
Last edit: 11 years 2 months ago by David Aiketgate.
Posted 11 years 2 months ago #127327
Only a leak in the passenger footwell..
Hence why people fit the TF snorkel when they do this mod
Time to create page: 0.594 seconds
