wheel bearings
Hi all
I was wondering how long a live these things have as mine have done 62k and the oe ones are know not to be the best quality
by helsbyman
- GT MG SPARES LTD
A simple jack up and rock about up and down should give some indication of any play.
Wayward steering is one sympton of a good indicator of a bearing problem on mgf mgtf although wayward steering can not be associated to bearings alone.
Last Edit:11 years 2 months ago
by GT MG SPARES LTD
Last edit: 11 years 2 months ago by GT MG SPARES LTD.
Hi
I don't have any problems yet.It's just it has done 61k and I was wondering the life of one.
by helsbyman
I replaced the osr one at 110,000 miles because it was shot. The other 3 were fine.
by billd
61k... They are just run in then HA HA
by helsbyman
Last edit: 11 years 2 months ago by helsbyman.
I seem to get through rear bearings quite quickly I am guessing its cheap quality?
Had a similar problem with a mini a few years ago, found out the hub was worn and so the bearings weren't being clamped up correctly.
by coxy134
The MGF /TF can also suffer from worn hubs so that the bearing is moving in there. Causing problems -only cure is replace the hubs.
Our F has done over 130,000 and has had one set of new wheel bearings in its lifetime so far.
- adamelphick
Meg needed a front passenger one at about 96K the rest were fine.
by adamelphick
Mine needed a N/S/R at 70k, all the others appear to be sound and original.
by PsPNuT
Time to create page: 0.519 seconds
