Calling all the plumbing heads....
Calling all the plumbing heads.... was created by bensewell
Posted 11 years 1 month ago #131498
My radiators stopped working a few week ago, well about 3-4 week ago.
Got a plumber out charged £30 to push the pressure up / fill water in the system, no idea if this is the technical term, basically in and out in about 5 minutes.
Same happened yesterday. Me and Nat were out at work all day and when we got in house was freezing.
Checked the bar pressure thing in the airing cupboard and it was at 0 bar. I've not got a clue about boilers so rang plumber man up.
He told me what to do to get it working again.
What I did was...
Theres a red small tank above the boiler, this is for the heating / radiator bit. I opened two tap things like the ones under the sink, I heard some water moving then the bar pressure thing went up to about 1.4. I shut the taps then cranked the heating up... NOTHING.
So did procedure again, this time with heating control thing turned off but I pressed the reset button on the boiler (in the garage). Then turned the thermostat up. That worked and we had hot radiators for a few hours.
Woke up this morning cold again, did the procedure a little bit, could feel radiators getting a bit hot so set off for work.
We have the plumber coming back on saturday to service the boiler / tank and generally check everything out for us.
But anyone know what it could be? Or if I've been doing things wrong.
Like I said I'm a right boiler pleb I no nowt abart em.
This is what it looks like, the two tap things:
[IMG
Is a potterton boiler
Replied by really? on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131501
Are you sure you're not losing coolant?
Check the long pipes that run under the floor from the boiler to the radiator
by really?
Replied by bensewell on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131502
I'm hoping not that or all our laminate might have to come up, the pipes run from the garage, under the floor then god knows where...
Might be a house insurance jobby if somethings majorly up. Just decorated too...
Grrrr
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131504
I'm thinking a leak, Radiators are a closed loop so once you've brought the pressure up , for the pressure to drop the water must be going somewhere, if it was coming back through the tap you turned i'd expect your bar to be at local mains pressure rather than zero, Zero would indicate a loss radiator loop side
Will be visiting one of my customers today who do boilers and stuff i'll ask them
by psymon
Posted 11 years 1 month ago #131505
in all seriousness im with psymon, its got to be going somewhere.
there's other things that will stop the boiler cutting in; but the fact youre losing pressure means it's going somewhere.. :nonod:
by really?
Replied by idrawcad on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131511
We had a similar thing last year with our boiler. It was the pressure vessel inside the boiler, which had lost its pressure. They put in a new pressure vessel and pumped it up, hey presto it worked, and not that expensive either.
Regards
Chris
Replied by highflyer1000 on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131513
easy enough to re-pressurise the system , mine looses down to about 1 bar fro 2.5 over around 6 months , it is all old though about 12 years , but with the extension going up most of the pipes are going to be rerouted, and a new boiler going in in the next 2 years,to loose it over such a short a time does say something is leaking, check all radiators at both valves and all the pipework you can see
Replied by Andy Lawrence on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131518
See if halfords can do a home visit.
I've heard their the experts at sorting coolant losses! :coat:
WHALE OIL BEEF HOOKED
Replied by David Aiketgate on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131527
As an amateur plumbing expert I can confirm you have a water leak somewhere, the pressure should stay pretty constant and only require topping up a couple of times a year. :yesnod:
Finding the leak is the problem.
Check under the boiler for water and then check each end of each radiator. If you find a wet patch, check all the fittings above. Hopefully it will just be a rad valve fitting that needs nipped up.
Last Edit:11 years 1 month ago by David Aiketgate
Last edit: 11 years 1 month ago by David Aiketgate.
Replied by Cobber on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131543
Have you buying burgers from McDonalds again? :nonod:
Your house has HGF! :omg:
This time stay away from bloody Halfords! :bust:
The following user(s) said Thank You: richandpaula, Andy Lawrence, idrawcad
Posted 11 years 1 month ago #131561
Our boiler had a pressure release valve, check that is working, when we had our problem, it would keep pushing water out of there.
Regards
Chris
Replied by richandpaula on topic Calling all the plumbing heads....
Posted 11 years 1 month ago #131562
David Aiketgate wrote: ...Finding the leak is the problem.
Top Tip for checking for leaks is to use tissue paper / loo roll as it shows up any moisture really clearly as a wet spot.
Time to create page: 0.847 seconds
