damper bolts
Gosh arent they expensive £1:85 per bolts. thought they would be £0:50 or so but it turns out they are a special metal grade [10.9 ]
by helsbyman
Is that from Rimmers or local?
Rimmer bros Runcorn known as MG PARTS
by helsbyman
I took a bolt down to the local steel stockholder place, I got 4 for £2.80 including washers and nuts.
Hi David
The washer is part of the bolt on the O/E bolt but good buy should have asked you to get them :lol:
Last Edit:11 years 3 weeks ago
by helsbyman
Last edit: 11 years 3 weeks ago by helsbyman.
The name for the bolt with the built in washer is an Atlas bolt, used extensively in car and other production line manufacturing; you can never forget to fit the washer!
by Badger
Of course you're talking TF bolts and I was taking F bolts, :doh: :doh:
Hi David
Rimmer want £3 per bolt for an F damper
by helsbyman
Time to create page: 0.496 seconds
