First MOT
My first MOT with this car booked for tomorrow, have done the usual and not so usual checks as per John's very useful guide. So fingers crossed. If it fails I may have to cancel Christmas to pay for it!
Regards
Chris
by idrawcad
Don't worry. It does no good.
Hope you get on better than I did mine failed on both head light lenses 2 tyres that had cracks in the side walls needed welding to rear outer sill and a few other bits that I can not think of at the minute I was not at all happy they wanted over £800 to put it right. I got in contact with a mates friend and he sorted it for under £300 not including tyres as he said they were passable but I am on the look out for some new ones before next summer. :woo2:
by John Pell
- Wizzywogga
- Journeyman MGer
Hi there, in my experience it's best to expect the worst and then when it passes or only needs minor work, then you're in the pound seats!! :woohoo:
You haven't got the dreaded SRS lit up have you? :bang:
Last Edit:11 years 1 week ago
by Wizzywogga
Last edit: 11 years 1 week ago by Wizzywogga. Reason: Bad spelling!
Oh Well. It failed on the following.
1 track rod end.
1 leaking shock
2 shocks with excessive play in the bottom bush
1no tyre delaminated in inside wall
So a set of GAZ shocks ordered and 2 Toyo tyres ( 1 was near limit)
Not the end of the world
1 track rod end.
1 leaking shock
Regards
Chris
by idrawcad
The bottom damper bushes can be replaced on an F, but seeing as you've already ordered the Gaz adjustables anyway.:shrug:
We are over the moon with the Gaz dampers we fitted to Jet Black. :yesnod: Just don't set them too stiff or you will damage the rear top mounts. 10 ish seems about right.
Last Edit:11 years 6 days ago
by David Aiketgate
Last edit: 11 years 6 days ago by David Aiketgate.
Time to create page: 0.511 seconds
