Fitting 52mm TB to an F
Fitting 52mm TB to an F was created by Forrester
Posted 10 years 11 months ago #136543
Have just bought a new 52mm TB for my '99 F.
Presume it's just a straight swop, but do I have to do anything else eg. the sensor?
The following user(s) said Thank You: Andy Lawrence
Replied by Andy Lawrence on topic Fitting 52mm TB to an F
Posted 10 years 11 months ago #136544
It takes about an hour if you go in engine cover way but it's still dooable through vent but fiddley!!
There's a how to on here with the reset procedure for the TPS cos it'll be wild on the tick over!!!
Good luck :broon:
WHALE OIL BEEF HOOKED
The following user(s) said Thank You: Leigh Ping, Forrester
Replied by John Pell on topic Fitting 52mm TB to an F
Posted 10 years 11 months ago #136552
Are you replacing the plastic 48mm throttle body if so let me know if you think it is worth it as kep thinking about getting one myself :beer:
Replied by Tourbillon on topic Fitting 52mm TB to an F
Posted 10 years 11 months ago #136558
No real bhp gain but the engine becomes very responsive to throttle movement in comparison to the 48mm, we'll worth doing I thought!
TB
The following user(s) said Thank You: Leigh Ping, John Pell
Replied by Leigh Ping on topic Fitting 52mm TB to an F
Posted 10 years 11 months ago #136566
Andy the tyre man wrote: There's a how to on here with the reset procedure for the TPS cos it'll be wild on the tick over!!!
Posted 10 years 11 months ago #136568
Tourbillon wrote: No real bhp gain but the engine becomes very responsive to throttle movement in comparison to the 48mm, we'll worth doing I thought!
TB
It's the noise it makes that makes ti worth doing!!!
Replied by stephen1473 on topic Fitting 52mm TB to an F
Posted 10 years 10 months ago #136615
If you swap your old throttle position sensor onto your new throttle body, you should have no need to do any setup, it should run normally from th start.
The following user(s) said Thank You: Forrester
Replied by paulsmgf on topic Fitting 52mm TB to an F
Posted 10 years 10 months ago #136616
stephen1473 wrote: If you swap your old throttle position sensor onto your new throttle body, you should have no need to do any setup, it should run normally from th start.
might not be the case as the TPS looks at the position of the throttle its attached to :(
Posted 10 years 10 months ago #136617
"Compare and contrast: the original black plastic ‘SU’ 48mm throttle body (right) next to the replacement ‘Dellorto’ 52mm throttle body (left).
A sensible step at this stage is to remove the throttle position sensor from the old throttle body and replace it for the one on the new throttle body (it is held on by just a couple of small bolts). Doing this avoids the need to visit a specialist with Rover's Testbook to reset MEMS calibration for the new sensor."
http://www.mgf.ultimatemg.com/group2/DIY/throttle_body_replacement/index.htm
Posted 10 years 10 months ago #136618
No specialists are needed its just a few pushes of the throttle pedal lol
Replied by talkingcars on topic Fitting 52mm TB to an F
Posted 10 years 10 months ago #136620
paulsmgf wrote: No specialists are needed its just a few pushes of the throttle pedal lol
Switch ignition to position 2, fully depress and release the gas peddle five times within thirty seconds, wait for the stepper to stop adjusting, start engine, throttle position sensor is reset, takes longer to type than to do.
Replied by Whiz on topic Fitting 52mm TB to an F
Posted 10 years 10 months ago #136903
hope you got this done now?
what you think?
i agree it feels extra responsive compared to my old 48mm :)
by Whiz
