flip key conversion
Replied by Fatbaldingoldgit on topic flip key conversion
Posted 10 years 10 months ago #137717
Bobbybrown on .org did a kit with blank keys and flip case with MG logo...I have one myself..dunno if he is still doing it..
- Frank Zappa
Replied by Tourbillon on topic flip key conversion
Posted 10 years 10 months ago #137718
Bertl
If you look on Org, there is a whole thread about flip keys. There is a guy on there doing them for pekron style fobs.
TB
Replied by Raccoon on topic flip key conversion
Posted 10 years 10 months ago #137719
Tourbillon wrote: Bertl
TB
Pektron are the oval shaped with three buttons, right?
I have the angled one with two buttons.
The one in the ebay link would be the correct shape I think, the blade seems to be the problem...
Sent pm to Bobbybrown, let's see...
Last Edit:10 years 10 months ago by Raccoon
Last edit: 10 years 10 months ago by Raccoon.
Replied by Rich in Vancouver on topic flip key conversion
Posted 10 years 10 months ago #137753
I got a kit from the guy on .org. If I recall correctly he has a choice of 2 key blades.
The kit was pretty straightforward once you get the spring figured out. It took a bit of
dremelling but wasn't bad. The only drawback is you have to glue the two halves of the
case togerher which makes changing the batteries a project.
Posted 10 years 10 months ago #137755
Rich in Vancouver wrote: I got a kit from the guy on .org. The only drawback is you have to glue the two halves of the
He solved that issue..the latest cases are screwed together..changing batteries is a doddle..
- Frank Zappa
Replied by adamelphick on topic flip key conversion
Posted 10 years 10 months ago #137771
Just a thought - if you glue it together how do you get it apart to change the battery when it dies?
Posted 10 years 10 months ago #137802
Dagnabit! Sometimes being an early adopter just doesn't pay off! :slapme:
Replied by David Aiketgate on topic flip key conversion
Posted 10 years 10 months ago #137811
I made one myself. Used it for a week, got bored with it and went back to standard set up!:shrug:
Replied by really? on topic flip key conversion
Posted 10 years 10 months ago #137814
i dismembered one of my flip keys so i could wear just the key blade around my neck when i'm in the sea :woo2:
don't trust those key safe things, they're just an advert that you're away from your car :dry:
by really?
Posted 10 years 9 months ago #139067
e voila:
Last Edit:10 years 9 months ago by Raccoon
Last edit: 10 years 9 months ago by Leigh Ping.
Time to create page: 2.487 seconds
