heater resistor values
heater resistor values was created by Raccoon
Posted 10 years 10 months ago #137911
ok, heater fan is working on two speeds only, time to replace the resistors.
I'm aware that it works with resistors similar to the original values, found different specs in several posts.
But does anybody know the exact values of the original resistor pack? :-?
by Raccoon
Replied by adamelphick on topic heater resistor values
Posted 10 years 10 months ago #137918
I've ordered the following from Maplin for Felix:
2* Wirewound 7 Watt 0.68 Ohm Resistor £1.58
2* Wirewound 7 Watt 0.22 Ohm Resistor £1.58
2* Wirewound 7 Watt 0.1 Ohm Resistor £1.58
The values were confirmed by Technozen on another forum...... I've used similar ones previously on my F and it's been fine since about 2007!
Last Edit:10 years 1 month ago by adamelphick
Last edit: 10 years 1 month ago by David Aiketgate.
Replied by Raccoon on topic heater resistor values
Posted 10 years 10 months ago #137919
... that's a new option...
read so far:
10W 1.5Ω
10W 0.68Ω
10W 0.27Ω
or:
11W 1.5Ω
11W 0.56Ω
11W 0.33Ω
alternatively when combining two resistors per contact:
2x 10W 3.3Ω
2x 10W 1.5Ω
2x 10W 0.56Ω
Apparently it's more important to have similar steps between the single resistors than having the 100% correct value,
am I right?
by Raccoon
Replied by adamelphick on topic Re:heater resistor values
Posted 10 years 9 months ago #137926
Yes keep them balanced.
The reason your last set are so wildly different is because they would be connected in parallel, effectively halving their resistance. That would bring them inline.
Tecnozen said that the values I gave you are as close to the right died while keeping the resistors fairly small (they droop of to long and heavy and may hit the fan blades if not tied together well enough).
Two of the 7 watt ones I got wired in series give you 14 watts which I'd enough capacity, and close enough to the right resistance for good speeds. At least I'll know that very soon lol.
Sent from my GT-N7105 using Tapatalk
Last Edit:10 years 9 months ago by adamelphick
Last edit: 10 years 9 months ago by adamelphick.
Replied by helsbyman on topic heater resistor values
Posted 10 years 9 months ago #137928
Rezpak on ebay have the right coils for the job at £6.40 diy or send your pack to them £13 and they do all the work [ this answer is also on F reg with the link to ebay ]
Posted 10 years 9 months ago #137942
helsbyman wrote: Rezpak on ebay have the right coils for the job at £6.40 diy or send your pack to them £13 and they do all the work [ this answer is also on F reg with the link to ebay ]
Originally I planned to use ceramic resistors but after reading Rezpax' description
I think I'll give them a try...
Thanks guys!
Last Edit:10 years 9 months ago by Raccoon
Last edit: 10 years 9 months ago by Raccoon.
Posted 10 years 9 months ago #137945
I'm gonna stick with ceramic as they are much stronger than wound wire.
Posted 10 years 9 months ago #137962
Picked up the resistors this afternoon. Got them soldered in to the resistor base and voila:
Popped it in to Felix and it works an absolute treat. All 4 speeds - nice and slow to super fast. As always I highly recommend the ceramic resistor path... it's the way to go and it's CHEAP! Total paid £4.74.
Posted 10 years 9 months ago #137967
adamelphick wrote: Picked up the resistors this afternoon. Got them soldered in to the resistor base and voila:
looks great!
Ordered from Rezpax yesterday as I did not find all resistors locally.
by Raccoon
Posted 10 years 9 months ago #137968
adamelphick wrote: I'm gonna stick with ceramic as they are much stronger than wound wire.
rezpak warranty for live and they are wire [stainless steel ]
Last Edit:10 years 9 months ago by helsbyman
Last edit: 10 years 9 months ago by helsbyman.
Posted 10 years 9 months ago #137969
Bertl wrote:
looks great!
When i ordered the rssistors from Maplin I got an email saying all 6 were in, then a text saying they only had 3 in stock! The helpline chat person said they were in but just in case to order equivalents - so I ordered a mixture of Series and Parallel resistors instead - when I got there today I went with my original order as they indeed did have them! LOL
Not the most efficient ordering system (plus their website is screwy when searching for local stock in Firefox!) - but they are cheap!
Once you've soldered the new ones on (whichever type), the removal / refit is quite quick. I did the whole thing in about 15 minutes. You can just lower the glovebox out of the way and leave the wires connected usually, and just ease the air inlet out of the way after undoing the one bolt - then just pop the air feed pipe out of the lower fixing and reach in behind - you'll see what I mean when you get it off!
Replied by Attila on topic heater resistor values
Posted 10 years 9 months ago #138112
Hello
What tools do u need exactly to take it out.
I saw 1 pdf somewhere its under the glove box.I got only a screw driver nothing else.What else should i buy.Are they providing replacement rpaired parts immidiately like as exchange ?
If i take it out 1 wanna put back the new 1 in 1 go.
by Attila
Time to create page: 0.516 seconds
