took a chance on fleabay, will this work?
took a chance on fleabay, will this work? was created by Denial
Posted 10 years 9 months ago #139237
PIPER CROSS AIR FILTER for Vauxhall corsa 2004
Seller information
bluffmystro (431 Feedback score: 431)
100% Positive Feedback
Follow this seller
See other items
Item condition:Used
Ended: 22 Feb, 2014 12:27:18 GMT
Winning bid:£0.99
[ 1 bid ]
So bought this on ebay, says for vauxhall corsa and ofc no pipe or fittings but any reason why i can't fit this to my tf? At 99p no big deal if i can't it was worth a punt
Thanks David, so what do i need? a piece of hose and some clips anything else?
Last Edit:10 years 9 months ago by Denial
Last edit: 10 years 9 months ago by Leigh Ping.
Replied by David Aiketgate on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139239
:broon: That's what I did. I think mine was off a Golf or something but they're basically the same unit. Just different hoses! :yesnod: :yesnod:
Last Edit:10 years 9 months ago by David Aiketgate
Last edit: 10 years 9 months ago by David Aiketgate.
Replied by Denial on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139240
by Denial
Replied by bensewell on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139241
Wait until you get it home then measure the throttle body end then the filter end.
Buy a reducer / enlarger pipe to fit both ends and jobs a good one.
Mine was going to have a golf VR6 induction but sold it to a ZR person instead.
I think with the hoses and clamps etc you will be well within then sub £40 budget.
Replied by stephen1473 on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139248
I nearly did this with my F, you will need a 90 degree elbow from the throttle body, to fit the enclosed filter, pointing in the correct direction. Also you have to clean the filter very very gently, it doesn't dismantle, you have to spray the fluid inside onto the dirty side, then use clean water flowing through from the opposite side. The foam filter is very fragile and prone to tear.
Last Edit:10 years 9 months ago by stephen1473
Last edit: 10 years 9 months ago by stephen1473.
Replied by talkingcars on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139260
I fitted a filter intended for a ZS.
I used a 45' bend.
Replied by Rich in Vancouver on topic took a chance on fleabay, will this work?
Posted 10 years 9 months ago #139314
I used a 45 as well with a length of flex hose from the filter down to the passenger side intake.
The filter assy is supported by a stainless boat fender bracket bolted on to the original mount
using a crankshaft pilot bush as a spacer. (It's OK, the bushing is from a TR-7!)
Last Edit:10 years 9 months ago by Rich in Vancouver
Last edit: 10 years 9 months ago by Rich in Vancouver.
Time to create page: 0.504 seconds
