52mm Throttle body found
52mm Throttle body found was created by Jonniey
Posted 10 years 8 months ago #139502
reading through posts i'm learning stuff, but this is what i found while changing the ignition leads
Theres a 52mm throttle body fitted and an aluminium inlet manifold, Now as she looks likes a base model i'm sure this are not standard fittings from the factory, Could someone shread any light on these parts and what performance if any these parts may produce??
Any info on these parts would be appreciated
she is an MGF year 2000 on the X reg, Non ABS, the only comforts are Elec winds & elec mirrors, NO aircon, cloth interia, so pretty basic model
by Jonniey
Replied by David Aiketgate on topic 52mm Throttle body found
Posted 10 years 8 months ago #139508
How do you know it's a 52mm?
Replied by Jonniey on topic 52mm Throttle body found
Posted 10 years 8 months ago #139520
David Aiketgate wrote: How do you know it's a 52mm?
it's alloy, it has delorto made in italy and 52 in the casting
by Jonniey
Posted 10 years 8 months ago #139526
That's a 52 then. ;) :bust:
The following user(s) said Thank You: Jonniey
Posted 10 years 8 months ago #139527
David Aiketgate wrote: That's a 52 then. ;) :bust:
am i right in thinking that, this is not standard factory fitting for this model and year? and some one has upgraded
Last Edit:10 years 8 months ago by Jonniey
Last edit: 10 years 8 months ago by Jonniey.
Posted 10 years 8 months ago #139531
Standard would be an alloy 48mm on a plastic manifold. The vvc had an alloy manifold.
Time to create page: 0.651 seconds
