what's that part?
what's that part? was created by Raccoon
Posted 10 years 8 months ago #139504
removed the engine cover today for the first time (that's another story) and found this part:
What is it for? Looks like a pressure sensor or similar.
And - more important - where should it be mounted?
Found it it laying in the 'compartment' below the seat belt unit, but not fixed in any way.
by Raccoon
Replied by David Aiketgate on topic what's that part?
Posted 10 years 8 months ago #139511
Is it connected via one of those small pipes to the inlet manifold? If so it's the control unit for the exhaust gas regulator valve on the standard offside tailpipe..
The following user(s) said Thank You: Raccoon
Replied by Raccoon on topic what's that part?
Posted 10 years 8 months ago #139515
it is connected to the inlet manifold.
shouldn't it be fixed somewhere?
by Raccoon
Replied by cjj on topic what's that part?
Posted 10 years 8 months ago #139519
It's usually fixed on the inner offside wing and controls the flap in the original exhaust.
If it has a non standard exhaust you can remove that unit, as long as you block where the unit connects to the inlet manifold, otherwise you will get an induction (Vacuum) leak.
Last Edit:10 years 8 months ago by cjj
Last edit: 10 years 8 months ago by cjj.
The following user(s) said Thank You: Raccoon, Argen69
Replied by Argen69 on topic what's that part?
Posted 10 years 8 months ago #139524
Good to know, as I'll not be needing that now I've ordered a Daytona :woohoo:
Last Edit:10 years 8 months ago by Argen69
Last edit: 10 years 8 months ago by Argen69.
Time to create page: 0.512 seconds
