Hard top heated window light on all the time
- sherwood0_8
Hard top heated window light on all the time was created by sherwood0_8
Posted 10 years 7 months ago #141905Please Log in or Create an account to join the conversation.
- stephen144
- Novice MGer
Replied by stephen144 on topic Hard top heated window light on all the time
Posted 10 years 7 months ago #141906Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Hard top heated window light on all the time
Posted 10 years 7 months ago #141943or
all the time when the ignition is on all the time or
or
all the time when the engine is running all the time?
- sherwood0_8
Replied by sherwood0_8 on topic Hard top heated window light on all the time
Posted 10 years 7 months ago #141952:omg: :omg: :omg:
Posted 10 years 7 months ago #141954The quick remedy is to pop the relay but I'd be checking the oil pressure switch, especially as this can effect other systems with in the ECU.
- sherwood0_8
Posted 10 years 7 months ago #142074Please Log in or Create an account to join the conversation.
Posted 10 years 7 months ago #142075
- John and Sue
Replied by John and Sue on topic Hard top heated window light on all the time
Posted 10 years 7 months ago #142099The HRW itself is only energised when the motor is running, not just when ignition is energised as with most cars that are not designed and built by Brummies.
If there is 12V at the rear window terminals when the key is out there is a hard fault.
If not it is an indication fault.
Stuff a meter into the terminals and measure with Ign off.
Let us know your findings.
- sherwood0_8
Posted 10 years 7 months ago #142140Please Log in or Create an account to join the conversation.
- Glenn de France
- Novice MGer
Replied by Glenn de France on topic Hard top heated window light on all the time
Posted 10 years 3 months ago #147947I had the same problem and after extensive troubleshooting and wiring checks (thanks to http://www.mgfcar.de/schedules/ and attached) the problem was with the Multi-Function ECU. This is the box mounted behind the fuse box with the part number YWC104500.
It seems that the relay for the HRW is powered from this box, (pin 4 from memory of the big plug). The problem for me was this box had failed and was constantly supplying 12V...even with the key out of the ignition (same as your defect). The light in the HRW switch is just the tell-tale to tell you that 12v is being supplied to the HRW...that is why it stays on all the time.
Replied by PQD44 on topic Hard top heated window light on all the time
Posted 10 years 3 months ago #147948Please Log in or Create an account to join the conversation.
- sherwood0_8
Posted 10 years 2 months ago #150260Please Log in or Create an account to join the conversation.
