fail mot
Well my car failed it's mot for the first time to day. It failed on the CO test and the HC test.
The CO was 0.91 the first time and 0.51 the second time and the HC passed the first time but failed the second time any ideas as to what needs doing as the mech was not very forth coming. Is it a new cat do you think? These were all on the fast idle, the natural idle was OK
Judging by the reduction in the second reading it looks as if the cat was just starting to get hot enough.
Can you give the car a damn good long thrashing and ask him to do the gas test as soon as you get there?
- Andy Lawrence
Too slow :coat:
WHALE OIL BEEF HOOKED
More modern cars are tending to put the cat directly after the exhaust manifold to solve this issue.
If the tickover emissions are OK, there could be an overfueling issue of course. Can you access the fault codes in OBD to check for sensor problems?
PO300 is random misfires.
- John and Sue
I put some Cataclean in the tank, new air filter and applied the Thrashdee- Knackerzoffit technique prior to the test. Sailed through.
John and Sue wrote: Ours failed on high HC when Sue dropped it off for test. I forgot to remind her to get it nicely hot. That said, the mech, who knows our cars, tried his best.
Mine only just got through on emissions last year so i took John's advice a couple of weeks ago and ran a can of CataClean through. The emissions this year are much lower than last.
TBH I cannot absolutely say that this is totally due to the CataClean as I've changes the throttle body to a 52mm version and put on a CDA induction kit. However, I was a bit concerned that these may have had an adverse effect, apparently not.
May be worth trying CataClean for £15 and getting the cat good and hot before the retest.
Good luck!
Robin
Robin
- John and Sue
Cheaper than t'shop.
