clutch failure, your opinion please?
clutch failure, your opinion please? was created by Raccoon
Posted 10 years 5 months ago #145591
yesterday the clutch in the better half's Lacetti failed...
The pedal became very soft and the clutch did not react any more, so no proper gear change possible.
I did not find the time to check it today, had a quick look at the brake fluid level only - between min and max.
Would you agree that the clutch master cylinder is the first part to check??
Can it be easily seen if the part is faulty?? :-?
Apologies for asking a question about a non-MG car - I assume some basics are similar on all cars...
by Raccoon
Replied by PQD44 on topic clutch failure, your opinion please?
Posted 10 years 5 months ago #145597
I'm confused, easily done, what does the brake fluid level have to do with the clutch?
Replied by Raccoon on topic clutch failure, your opinion please?
Posted 10 years 5 months ago #145598
aren't both circuits fed from the same reservoir???
by Raccoon
Replied by cairnsys on topic clutch failure, your opinion please?
Posted 10 years 5 months ago #145599
I've never heard of that. Has the Lacetti got a hydraulic clutch or is it cable operated?
Posted 10 years 5 months ago #145600
Bertl wrote: aren't both circuits fed from the same reservoir???
Not on any car I've ever owned.
Posted 10 years 5 months ago #145601
just had a look at some technical drawings.
It has a hydraulic clutch actually, the clutch master cylinder (1) is fed from the break fluid reservoir through hose 5:
So my idea was that there may be a leak somewhere that causes the soft pedal by too low pressure, the impulse from the clutch pedal is not transmitted to the clutch plate.
Or does this sound nonsense??
Will dive a little deeper tomorrow.
by Raccoon
Posted 10 years 5 months ago #145604
The reservoir is simply a feed for the clutch master cylinder, if you're losing pressure after pushing the clutch pedal any leak must be on the other side. Check for any leaks on the brake master cylinder and all parts from there to the pipe marked 12.
The following user(s) said Thank You: Raccoon
Replied by David Aiketgate on topic clutch failure, your opinion please?
Posted 10 years 5 months ago #145606
I had to google Lacetti to find out what you were talking about... :dry:
Posted 10 years 5 months ago #145607
Probably most well known as Top Gear's second reasonably priced car. They used it from 2006 to 2010.
Looked very similar to the first reasonably priced car, the Suzuki Liani.
Last Edit:10 years 5 months ago by PQD44
Last edit: 10 years 5 months ago by PQD44. Reason: add photo of Liana
Posted 10 years 5 months ago #145639
ok, found the reason - air in the system.
After bleeding it works again as it should.
Now I only have to find the reason for the air bubbles... :dry:
by Raccoon
Posted 10 years 5 months ago #145652
:woo2: Good news, that must be a weight off your mind.
Last edit: 10 years 5 months ago by David Aiketgate.
Time to create page: 0.627 seconds
