Correct coolant for 2005 MGTF
Correct coolant for 2005 MGTF was created by Branchman
Posted 10 years 3 months ago #148379
Once again I would like some Help
Having drained the cooling system to fit Stainless under floor pipes now need to now the correct replacement fluid, the old stuff was orange/pink and have seen remarks about not mixing with other coolants (cannot flush system at this point as the car is on Stands/Ramps in my garage) or should I wait till all other jobs done remove from garage then flush and refill.
Last Edit:10 years 3 months ago by Branchman
Last edit: 10 years 3 months ago by Branchman.
Replied by Badger on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148381
The recommended coolant is OAT (organic acid technology) available from any motor factor.
The total coolant capacity is around 10 litres so you need 5 litres of OAT antifreeze to give you a 50% mix.
Brian.
by Badger
The following user(s) said Thank You: Branchman
Replied by g4hlr on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148383
Alternatively you could use Castrol's 4 Life coolant. It's got a minimum 10 year useful life and is almost designed for MGF/TF's as it changes colour in the event of the beginnings of HGF! It is waterless and has a much wider cooling range than standard or OAT coolant. Yes it's a bit dearer at about £19 for 5L but, as it lasts up to four times longer it's cheaper in the long run - and a darned sight more efficient.
But at the end of the day yer pays yer money and takes yer choice. Cheers
by g4hlr
Replied by talkingcars on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148387
OAT - don't be confused by colour, different brands come in different colours.
Replied by David Aiketgate on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148397
A 2005 will have had OAT coolant in from new. There should be a yellow notice around the expansion tank cap informing you to only fill with OAT. The pink/orange colour is likely to be Halfords OAT. It has a very distinctive orange/pink colouration.
Replied by Blow-in on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148407
I use Comma Xstream G30 bought in 5 litre 'cans' from Autosave (dilutes with water to 10 litres).
Product details here: http://www.commaoil.com/productsguide/view/6/351
It's pink in colour too.
Richard
by Blow-in
Posted 10 years 3 months ago #148408
Blow-in wrote: I use Comma Xstream G30 bought in 5 litre 'cans' from Autosave (dilutes with water to 10 litres).
Richard
I stand corrected - it's violet in colour
File Attachment:
File Name: CommaXstre...data.pdf
File Size:95 KB
R
by Blow-in
Replied by Branchman on topic Correct coolant for 2005 MGTF
Posted 10 years 3 months ago #148412
Thank you all for your help will obtain The suggested coolant as soon as I fix the sheared bleed screw in the front bulkhead (see in the SH*t topic)
Time to create page: 0.511 seconds
