In The Sh*t
only thing is I don't think the bleed valve moved at all so it may still be sealed but not sure if leaving it will cause heating problems HEEEEELP
You may have an air lock otherwise which can cause serious overheating problems when it reaches the wrong point in the system.
Do you have a chance to weld on another head an top or to cut a furrow to apply a tool?
Give it a good soak with WD40.
EDIT David Aiketgate added:-
Use a penetrating spray rather than WD40 e.g. Plusgas. It's much more effective!
Can you drill a hole in it and use a screw extractor / easyout ??
http://www.the-t-bar.com/forum/tooltime/90572-screw-extractors
Hope that helps. Let us know how it goes.
- Leigh Ping
:welcome:
- Agaserviceguy
- Apprentice MGer
Please could some one clarify, I thought the correct size for an 8mm tap was 6.9 but note in one comment a size of 6.8 was recommended (having just ordered a pack of 6.9mm Drills)
https://www.carbidedepot.com/formulas-tap-metric.htm
- Leigh Ping
Davem wrote: Its great you got it sorted. :clap:
Yep, it's great that you've sorted the problem out. Some pics, if you can, might help others who get the same issue. Also, we'd like to see your ingenuity. :broon:
Brian.
Once again THANKS! will post Pics as soon as I have tapped out for bleed screw and finished job.
