In The Sh*t
In The Sh*t was created by Branchman
Posted 10 years 3 months ago #148380
Thought I would slacken the bleed screw for the heater ready, to fill coolant system ( once I knew which fluid to use) Guess What? the thing has sheared so now need ideas on how to remove heater unit or any other ideas to solve problem
only thing is I don't think the bleed valve moved at all so it may still be sealed but not sure if leaving it will cause heating problems HEEEEELP :-?
Replied by Raccoon on topic In The Sh*t
Posted 10 years 3 months ago #148382
it's essential to bleed the system at all three points after refilling the system.
You may have an air lock otherwise which can cause serious overheating problems when it reaches the wrong point in the system.
Do you have a chance to weld on another head an top or to cut a furrow to apply a tool?
Give it a good soak with WD40.
EDIT David Aiketgate added:-
Use a penetrating spray rather than WD40 e.g. Plusgas. It's much more effective!
Last Edit:10 years 3 months ago by Raccoon
Last edit: 10 years 3 months ago by David Aiketgate. Reason: more info
Replied by talkingcars on topic In The Sh*t
Posted 10 years 3 months ago #148388
As a quick fix just disconnect the hoses from the heater and cap them.
Replied by Davem on topic In The Sh*t
Posted 10 years 3 months ago #148389
Yep sounds like you are up
Can you drill a hole in it and use a screw extractor / easyout ??
http://www.the-t-bar.com/forum/tooltime/90572-screw-extractors
Hope that helps. Let us know how it goes.
[IMG]ht[/img]
by Davem
Replied by Leigh Ping on topic In The Sh*t
Posted 10 years 3 months ago #148390
What the 3 guys above said and some pics of your problem might help us to help you better. :yesnod:
:welcome:
Replied by Agaserviceguy on topic In The Sh*t
Posted 10 years 3 months ago #148395
worth buying a small left handed drill bit sometimes the action of carefully drilling the hole will ease out whats left of the screw
Replied by Branchman on topic In The Sh*t
Posted 10 years 3 months ago #148414
Thanks for all your ideas have managed to drill and extract (with stud extractor) out the broken part then re-tapped out the thread but as this may not be a tight fit had a friend make up a small extension which I intend to screw and seal in place, then fit a new Bleed screw/nipple into the short extension (made from Stainless steel) so easier to get to and no more Seizing of the bleed screw.
Please could some one clarify, I thought the correct size for an 8mm tap was 6.9 but note in one comment a size of 6.8 was recommended (having just ordered a pack of 6.9mm Drills)
Posted 10 years 3 months ago #148416
Its great you got it sorted. :clap: :clap:
https://www.carbidedepot.com/formulas-tap-metric.htm
[IMG]ht[/img]
by Davem
Posted 10 years 3 months ago #148419
Davem wrote: Its great you got it sorted. :clap:
Yep, it's great that you've sorted the problem out. Some pics, if you can, might help others who get the same issue. Also, we'd like to see your ingenuity. :broon:
Replied by Badger on topic In The Sh*t
Posted 10 years 3 months ago #148421
BSI / ISO standard tapping size drill for M8 x 1.25 pitch is 6.8mm as per my previous post. Your 6.9mm drill is only 0.1mm bigger which is just under 4 thou (0.0039") and will make no noticeable difference after tapping out just for a bleed nipple.
Brian.
by Badger
Posted 10 years 3 months ago #148428
Thanks to ALL members for your help am now ordering 6.8mm drills (will save the 6.9mm already ordered for some future job) as I want a tight fit for the bleed screw (coated with copper slip) and place a copper washer between the old bleed screw fitting and my short extension.
Once again THANKS! will post Pics as soon as I have tapped out for bleed screw and finished job.
Time to create page: 1.397 seconds
