SRS LIGHT OF DEATH
- sherwood0_8
I been doing bits and bobs to my F getting it ready to un sorn and get on the road again and have the SRS light on.
Now the drivers seat has always been a bit temperamental with the SRS light coming on now and then but usually a quick move forward and back of the seat and its off but today it just staying on I powered down the car and cleaned the contacts but still on. I have ordered a new pre tensioner will this do the trick ???? any help would be great
Last Edit:10 years 2 months ago
by sherwood0_8
Last edit: 10 years 2 months ago by sherwood0_8.
It's usually either the plugs under the seat or the rotary coupler behind the steering wheel.
I replaced my plugs with bullet connectors and the problem went away.
Check the fuse too. On my car it's the lonely fuse on the left of the fusebox under the steering wheel.
by David Aiketgate
Last edit: 10 years 2 months ago by David Aiketgate.
- sherwood0_8
Thank you I will check fuse first thing in the morning
by sherwood0_8
I've solved the same problem twice by replacing the control unit located in th centre console area ,,on 2 different cars
by paulsmgf
The following user(s) said Thank You: Leigh Ping, sherwood0_8
- sherwood0_8
Is that a srs control unit ?? is that in the main console part number if I need to replace ?? cheers
by sherwood0_8
- bryan young
Thank you David, that is a good diagram to have for reference. I believed that the Yellow SRS fuse should not be removed without first discharging the system?????
by bryan young
- sherwood0_8
Well its not the fuse is that SRS module in the centre console bottom under cubby hole???
by sherwood0_8
yes thats where it is ,possible to remove the foot well kick plates and twisty fingers get it out ,but if you have a spare srs unit it can be plugged in in situ before removing the origional for testing purposes ,if you were closer to me you could of tried mine out
by paulsmgf
The following user(s) said Thank You: sherwood0_8
- sherwood0_8
All fixed sorted Very Happy chap now I was changing a control unit behind the fuse bored and figured out whilst I had my tools out would have a look at SRS wiring all seemed to be ok so popped off the Air bag and the connection behind pushed in quite a bit so must have been that loose plug pushed back in after a quick blow inside to remove any dust fired her up and now no SRS
light :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
by sherwood0_8
Time to create page: 1.456 seconds
