Heated rear window problem
Heated rear window problem was created by Simondi
Posted 10 years 2 months ago #150933
Here's an odd one. :-?
As per another thread I have fitted an MGFmania rear window and wired up the heated rear screen.
SWMBO headed off to work today but the heated rear window would not switch off - even after the ignition was switched off. Result one flat battery.
So I've removed the relay which was pretty hot but clearly need to get this fixed. Any suggestions?
Cheers
by Simondi
Replied by David Aiketgate on topic Heated rear window problem
Posted 10 years 2 months ago #150937
Could be faulty switch, the relay or the wiring has been altered. The trigger feed to the relay should only work on ign 2 position.
The following user(s) said Thank You: Simondi
Replied by bryan young on topic Heated rear window problem
Posted 10 years 2 months ago #150943
And the Heated Rear window won't work (or should not) without the engine running, Like David, I suggest a faulty relay
Replied by Badger on topic Heated rear window problem
Posted 10 years 2 months ago #150945
The power feed to energise the relay coil and the power supply of the relay are a common feed from F7 in the fusebox of the drivers footwell, F7 is feed from the underbonnet link 5&6 via the ignition switch so if the ignition switch is off F7 has no supply, so the HRW relay will not be powered.
Put the relay back in start the engine, switch on the HRW then pull F7, the HRW relay should de-energise, the HRW switch illumination should go out.
I think you have an incorrect feed from somewhere, there must also be a switch ground issue, as when the engine is not running the BCU takes the ground signal away from the HRW relay coil; so there are 2 problems to check, the power supply feed and ground signal.
PM me if the want the HRW wiring diagram page for (>MY03 MGTF)
Brian.
by Badger
Replied by Simondi on topic Heated rear window problem
Posted 10 years 2 months ago #150946
Thanks for the replies I'll check out the relay etc
by Simondi
Replied by sherwood0_8 on topic Heated rear window problem
Posted 10 years 2 months ago #150947
I just fix this problem on my car last week check out this post about it
http://www.the-t-bar.com/forum/68-the-t-bar/91294-hard-top-heated-window-light-on-all-the-time
sounds like the same thing as mine hope this helps its easy to do just undo two nuts holding fuse board in and turn around clip out two leads and swop box.
This fault was draining my battery you might want to pull the fuse until you get it fixed. B)
MGF, MG TF, ZR ,ZS Multi Function Relay Unit YWC104500
Completed
Last Edit:10 years 2 months ago by sherwood0_8
Last edit: 10 years 2 months ago by sherwood0_8.
Posted 10 years 2 months ago #150953
sherwood0_8 wrote: I just fix this problem on my car last week check out this post about it
Completed
It's a different system with different control components on a MGF to the TF.
But very good information for the MGF owners on the T Bar.
by Badger
The following user(s) said Thank You: Leigh Ping, sherwood0_8
Replied by talkingcars on topic Heated rear window problem
Posted 10 years 1 month ago #150976
The heated rear window should only work when the oil pressure light goes out, it is wired that way so it only works with a running engine.
Posted 10 years 1 month ago #150989
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /var/www/vhosts/the-t-bar.com/httpdocs/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
Posted 10 years 1 month ago #151000
The relay is just a standard automotive relay. Mine came from Maplins and it's worked for 4 years. :yesnod:
Posted 10 years 1 month ago #151014
Just to confirm we are on the right track; I thought the issue was an 03 TF, if so we may on the mini relay as below.
If so go back to my earlier posts above.
Brian.
by Badger
Time to create page: 3.387 seconds
