Spot the difference....
'ere! Somebody's nicked yer seats! :omg:
Close..... well actually no you're not close!
Oh and it's got nothing to do with vacuum cleaners either :pop:
by DavesZed
new carpets per chance? Thats my next job also. Mine are coming off around the edges and are full of holes now
by Sithmaull
Yep new (fresh) carpet. From a late TF in absolutely mint condition.
The only thing though is that I have MK1 red mats so you don't end up seeing much of the carpet, but at least I know how bad the old one was (and that was VERY bad).
3 hour job from start to finish, very pleased
Top Tip for anyone doing this.....
If you have an F and you're putting a TF carpet into it you have to remove the underlay and the shaped foam, but NOT the underlay where your feet go against the bulkhead. You also have to cut the foam for where the window ECU goes (next to the drivers right foot)
by DavesZed
Looks great. It looks like you found a pen, but did you find enough change to pay for the job? Lol. I found 1/2 a ton of builders sand when I took my passenger seat out to fix the bodged coolant level alarm. Yuk!
Sent from my iPad mini using Tapatalk
by Argen69
The following user(s) said Thank You: DavesZed
Found no money at all, but then I've had these seats out before
It's amazing how much crap ends up under the seats, mostly blown in when you have the roof off, and as my roof is off most of the time (not today though by the looks of the weather forecast :nonod: ) it does get a lot in it :drive:
I would of done an how-to but I believe there is one somewhere, and it really is straight forward anyway... no really it is!
by DavesZed
Time to create page: 0.510 seconds
