Winter projects
Sorry I've been quite during the summer, been far too busy enjoying the TF and Mini Cooper, having holidays and helping various friends and family.
Anyway the TF is SORNed for the winter and there are a few jobs todo before the new summer season in April.
1) the steering is very vague around dead centre, I've seen comment that this is common on mgf/TF but it's definitely worse than it used to be and scares the wife. The only thing I didn't replace when i did the front subframe was the steering rack, but many of the parts were not OEM so I could have fallen victim to cheap Chinese crap. Also the tyres up front are GD2s, but Toyo's on the rear, am reluctant ant to replace as they have 5mm tread, any pointers?
2) either battery or starter is failing, when the battery is fully charged it turns over, catches and fires up, but there is a definite slow down during the process, and when I did a short journey there wasn't enough juice to start her. Was ok with a bump. The battery is just 5 years old and a good quality Varta one so I'm in two minds as to battery or starter. Any thoughts?
3) I need to get the xpower splitter fitted. Just need to find some who will do it at reasonable cost.
So not a long list but may take some time as I have some other demands on my cash and time.
Sent from my iPad mini using Tapatalk
- Fatbaldingoldgit
Argen69 wrote: Hi all,
I had the same problem despite getting the wheels aligned..changed the front GSD2s to Toyos..problem solved... :yesnod:
- Frank Zappa
Thanks FatbaldingOldgit
1) the vague steering turned out to be a loose steering rack. The nyloc nuts have been torqued up, but I will have too keep an eye on it when the car is returned to the road in the spring.
2) A new battery has been fitted and the car now starts more than once without having to recharge the battery
Next jobs/advice please...
A) I noticed the front discs are quite worn, any one know what the minimum thickness is before they need to be changed?
do I have to remove the door card to replace the speaker grills?
AP front discs are 24mm new and 22mm service limit.
If you are laying up for the winter like me fit an isolation switch for the battery; they just bolt in place with no mods to the battery cables (saves having to charge the battery once a month)
Regarding your steering; I see you found the problem but if the sub frames have been off they never go back in exactly the same position due to the elongated slots in the mounts, after re-fitting the frames I had a Hunter 4 wheel alignment done and it made a noticeable difference.
Brian.
Brian.
I'm in two minds on that. If the battery is isolated the alarm will be off.
David Aiketgate wrote: Yes door card off for the speaker grills. :yesnod:
Great that gives me an excuse to buy those alloy door lock pulls at last!
