interior door handle
interior door handle was created by CR41G
Posted 9 years 10 months ago #155000
Ive broke the plastic clip on the interior door handle that holds the rod in place ... is there any shops or dealers that I can get this poxy bit of plastic from??
Have to open the window to use the outside door handle to get out bloody thing!!
Thanks
by CR41G
Replied by David Aiketgate on topic interior door handle
Posted 9 years 10 months ago #155001
Try MGFnTF bitz. You may have to buy the complete mechanism.:shrug:
Replied by Sithmaull on topic interior door handle
Posted 9 years 10 months ago #155002
Surely rimmer bros would sell this part on its own?
Replied by CR41G on topic interior door handle
Posted 9 years 10 months ago #155006
Ive found a part number - fyc100260
Not sure if this is correct or even for a tf can anyone check?? Ive found this part on rimmers for just over 4 quid but want to double check its right before I spunk 4 quid on a tiny piece of plastic!!
Its needed for my driver door ,On rimmers though its showing for a left hand door and not the drivers side like I need .
any help part numbers or part diagrams welcome
by CR41G
Posted 9 years 10 months ago #155008
Ok scrap the my last post ive found the following part number and put it into rimmer bros website - fyc100250
Its showings as a right hand side (drivers) click snap sack .. it looks the same as the one that I broke but its green on rimmers and the one I took out was white.
can some one please let me no if this is the right clip that connects the interior door lock rod to the interior door handle release??
Cheers
by CR41G
Posted 9 years 10 months ago #155010
FYC100250 is the clip that holds the rod in place. If that's what you are looking for. :yesnod:
The following user(s) said Thank You: CR41G
Posted 9 years 10 months ago #155018
Thanks david ...part on order and while I was there I ordered a spare expansion tank cap.
had a few issues with her over the christmas period but nuthin to major then I get to work this morning and cant get out of it.
I took door card off to see the rod was out the handle hole . Pushed it back in place thinkin that was an easy fix and againil it poped out and I couldnt get out of it again , then found the broken bit of clip that the cable sits in and realised I need a new one ... first post was a bit short and to the point so my apologies for that I was pissed off with it and I was stuck at work
by CR41G
Posted 9 years 10 months ago #155061
I can now get out of my car without having to open the window and use the exterior door handle ...yaaayyyy!!!
For reference the part is called a clip-snap sack and part number for drivers side is fyc100250 and passengers door part number is fyc100260.
Easy job to do took 15 mins . Stupid little clip that if it breaks the handle bar retaining bit the bar pops out and renders the interior door handle / release useless . £4.10 from rimmer bros which believe it or not was cheaper than I found for a used one on ebay !!
I changed my expansion tank cap aswell as it arrived with the clip ..ive been loosing a couple of mm of coolant every few months but without any leaks from the system . I bled the system and all was well so only thing it could be was the cap valve had gone faulty which ive read is also quite common so ill c how it goes now ive changed that .
by CR41G
The following user(s) said Thank You: talkingcars, cairnsys
Time to create page: 0.504 seconds
