front fogs
front fogs was created by CR41G
Posted 9 years 9 months ago #156001
Im lookin at fitting fogs into my tf and was curious which fog lights fit??
Are all mg and rover fog light units the same for all models??
Eg would rover 25 or mg zr fog lights fit the tf?? Or will only tf specific fogs fit??
Also ive read that I need the mounting brackets for them to be installed into the bumper ... but also heard that some cars came with the mounting brackets already installed in the bumper ... if this is the case from what year was they fitted to as standard??
For referance my cars was registered in mid september 03 and is on a 53 plate
cheers folks
by CR41G
Replied by VADIM on topic front fogs
Posted 9 years 9 months ago #156003
You are correct to think for themselves to resist the fog SAME LIGHTS ROVER 25 and 200 and ZR BUT HANG ON THE INSIDE DIFFERENT from what year were put maybe it's the individual items for which you have had to pay
by VADIM
Replied by Forrester on topic front fogs
Posted 9 years 9 months ago #156004
I already have fogs on my 160, but as usual, find the light output poor.
Are there better bulbs available or even replacement lamps that will fit ok?
Replied by David Aiketgate on topic front fogs
Posted 9 years 9 months ago #156006
Other than get under and look there's no easy way to find out if your car has the brackets I imagine that on the TF if you remove the blanking plates you'll be able to feel the brackets if they are there.:shrug: Anyone confirm that?
Last Edit:9 years 9 months ago by David Aiketgate
Last edit: 9 years 9 months ago by David Aiketgate.
The following user(s) said Thank You: CR41G
Posted 9 years 9 months ago #156007
You can get Nightbreakers in H3 fitting which I think is what the fog bulbs are.
The following user(s) said Thank You: Forrester
Replied by CR41G on topic front fogs
Posted 9 years 9 months ago #156018
Ill have a look in a minute to see if the brackets are there and report back.
Can anyone confirm if I need to purchase tf specific fogs or would any other rover or mg fogs fit .
I ask the question because theres plenty on ebay but they all say for rover 25/45/75 mg zr/zs/zt/tf .. I dont want to buy and then not fit
by CR41G
Posted 9 years 9 months ago #156023
Update ... mine doesnt have the brackets fitted as standard
by CR41G
Replied by Sithmaull on topic front fogs
Posted 9 years 9 months ago #156029
I know its an F rather Than a TF but when i took the front bumper off my F the fog lights were attached to the car rather than the bumper using the plastic surrounds around the lights.
Posted 9 years 9 months ago #156030
Looking at this Tf bumper on ebay yours i would imagine is the same inside.
Posted 9 years 9 months ago #156031
This is where mine were mounted to the car. I have the lights on ebay for sale at the moment.
Posted 9 years 9 months ago #156069
Ohhh lol I asumed they were mounted to the bumper ... ill have to get a torch and have a look but failing that ill drop the bumper
by CR41G
Posted 9 years 9 months ago #156072
Mine was an F mind not a TF so it may be different. Worth a look though.
Time to create page: 0.542 seconds
