Machine gun door lock rattle
Machine gun door lock rattle was created by sherwood0_8
Posted 9 years 4 months ago #160964
Hello alas as soon as one problem is fixed another arises
My question is this do I need to replace or will a good blast of WD40 sort out this noisy culprit
It's not doing it all the time I am just worried the lock will give up the ghost and I will be stuck with a locked door that's a pig to get open !
Cheers
Replied by Andy Lawrence on topic Machine gun door lock rattle
Posted 9 years 4 months ago #160966
DONT DOUBLE LOCK YOUR DOOR TILL ITS FIXED!!!!
Look in the how to's for the solution.
WHALE OIL BEEF HOOKED
Replied by sherwood0_8 on topic Re:Machine gun door lock rattle
Posted 9 years 4 months ago #160973
Yes I was thinking that off I go to the breakers AGAIN lol
Replied by David Aiketgate on topic Re:Machine gun door lock rattle
Posted 9 years 4 months ago #160974
Just ensure you get a central locking type mechanism. ie It's not from a 1.6. They look outwardly similar.
Posted 9 years 4 months ago #160975
Well I don't think it's the door lock just swapped over two from scrap opening and closing fine but making machine gun noise now and then just noticed lights not blinking again when locking wiggled boot loom and its working again could it be the boot loom making the lock do this
Posted 9 years 4 months ago #160989
The boot loom is responsible for all kinds of electrical weirdness! :dry:
Posted 9 years 4 months ago #160992
checked all joins in the loom as it was repaired before one or two soldered joints looked a bit dodgy so re soldered and working once again.
I think I am going to hack some wiring loom from scrap yard and splice a join further up if this happens again :nonod: :nonod: :nonod: :nonod: :nonod:
Last Edit:9 years 4 months ago by sherwood0_8
Last edit: 9 years 4 months ago by sherwood0_8.
Time to create page: 0.504 seconds
