THE FOG AND NIGHT TIME NUMB NUTS.
- mgtfbluestreak
Replied by mgtfbluestreak on topic THE FOG AND NIGHTIME NUM NUTS.
Posted 8 years 3 weeks ago #173067Please Log in or Create an account to join the conversation.
Robin
cairnsys wrote: One of my pet hates at the moment are the idiots who drive in poor visibility on DRLs, not knowing or caring that they only show at the front. Almost as bad as driving with no lights, certainly from behind.
I agree. Just as bad are DRLs only in 'normal' darkness. Apart from the general lack of rear lights, the DRLs dazzle.
My Suzuki S-Cross SZ5 has a great arrangement. The DRLs are the front sidelights and go off with the head lights but if you select side lights only, they stay on and the rear lights come on too - this gives you all the options so in Daylight (the D in DRL) and normal visibility I can use front DRLs with rear lights. As this is obviously legal, I've rewired the DRLs on the MGF to give me the same option. I live in an area with a lot of trees and it can be pretty dark under them. I think DRLs are a really good thing used sensibly and combined with rear lights in normal daylight is a good option. Not in fog though!
Richard
Replied by David Aiketgate on topic THE FOG AND NIGHTIME NUM NUTS.
Posted 8 years 3 weeks ago #173073David
- Tourbillon
David Aiketgate wrote: Sounds interesting! Cough...How to?....Cough
David, I did a 'how-to' when I fitted the lights. Originally, I connected the DRL sensor to the side light circuit so that when the sidelights were switched on the DRLs went out. To change to my current system I reconnected the sensor to the dipped head lamp supply which works on the F as the main beam lights are separate and the dipped lights stay on even with main selected which means the DRLs switch off - does that make sense? I can take a photo if that helps.
Richard
Posted 8 years 3 weeks ago #173089David
David Aiketgate wrote: AH yes. I thought you meant that you could just have the rear side lights with the DRLs :dry: , but this way the front and rear sidelights will be on. :broon:
That's correct. I have LEDs in the front sidelights to reduce the temperature which as we know can play havoc with the reflectors. The DRLs are way more visible though than the LED sides.
Richard
- The driving dutchman
Replied by The driving dutchman on topic Re:THE FOG AND NIGHT TIME NUMB NUTS.
Posted 8 years 2 weeks ago #173209Another thing. In my Honda crv the instrumentpanel has one sign for both the sidelides as the main beam. So it does not warn you when you accidentally run with sidelights on....strange isnt it?
- mgtfbluestreak
Replied by mgtfbluestreak on topic Re:THE FOG AND NIGHT TIME NUMB NUTS.
Posted 8 years 2 weeks ago #173210Please Log in or Create an account to join the conversation.
