laptop battery isues
- mgtfbluestreak
- mgtfbluestreak
PC world is usually just to dear and they probably wont stock your models battery anyway.
- mgtfbluestreak
- p24hrsmith
I bought a non genuine battery for a small Dell notebook type laptop I have.The only issue was that the computer kept telling me it didn't recognise the battery and wouldn't charge it if the computer was in use. It charged fine when the machine was off though, and would run on AC without issue.
So just a note of caution that there may be some electronic tag on a genuine battery. No idea if Toshiba have a similar system to Dell.:shrug:
- mgtfbluestreak
just got in after a drive out.....naffed off without the laptop.......but hey just read this post and hey yes the laptop works im back on line again...i will temp use it like this till i buy a new battery...p24hrsmith wrote: Have you tried removing battery and see if it boots up because most laptops will boot just on an A/C supply my Dell does having said that as a rule they work with a dead battery too so laptop maybe in hibernation and software maybe preventing it starting until battery is charged or replaced but if you remove the battery and disconnect power leave for about 15 min then try booting with just power supply connected it should boot up then you can at least use it until you get new battery
- mgtfbluestreak
yes i know what you mean.....i used non genuine inks on .my printer and i had had enough of flashing lights telling me the ink was empty and there was a error......i can just imagine this pc telling me the battery needs attentionDavid Aiketgate wrote: All good info above. :broon:
