Grease gun recommendations
Grease gun recommendations was created by SeanJ
Posted 8 years 3 months ago #170377
Hi all,
Can anyone recommend a grease gun that won't break the bank please? Most of the ones I'm looking at seem to get wildly varying reviews :bang:
It looks like a trigger type is the way forwards, and from what I can see the bigger ones have way cheaper cartridges. I was looking at he the Clarke CGG120 - anyone use one? If not what do you guys use?
Cheers
Sean
by SeanJ
Replied by Badger on topic Grease gun recommendations
Posted 8 years 3 months ago #170379
Grease guns are somewhat a thing of the past as all modern cars have pre-greased sealed for life bearings, bushes and ball joints. I have a Wanner grease gun which is probably as old as I am and will obviously outlast me.
I think they are all made in China these days like the Clarke gun you mention, a pump leaver action with a flexible hose is the way to go, some you have to open and manual fill others take grease cartridges and some do both.
The one in the link below from Flea Bay will be the same low Chinese quality as the Clarke gun but comes with a grease cartridge which will probably last the life of your car; either will do the job no problem.
120CC PISTOL GRIP GREASE GUN SET WITH ACCESSORIES CARTRIDGE FLEXIBLE HOSE KIT
Completed
Completed
Brian.
Last Edit:8 years 3 months ago by Badger
Last edit: 8 years 3 months ago by David Aiketgate. Reason: added widget
The following user(s) said Thank You: SeanJ
Replied by Bob Essex on topic Grease gun recommendations
Posted 8 years 3 months ago #170382
I thought my grease gun days were long gone until I discovered (courtesy of The T-Bar) that the TF has two grease points on the front suspension. I suspect that lack of grease could be responsible for a nearside creak going over low bumps, so have been looking for a low cost grease gun but, so far, have shied away from Ebay. If anyone has tried the one suggested, it would be good to know.
Bob
Replied by martin l on topic Grease gun recommendations
Posted 8 years 3 months ago #170385
I bought a cheapo grease gun off ebay last week seemed to work ok. Only £12.50 including grease
PROFESSIONAL PISTOL GRIP MANUAL GREASE GUN SET 120CC WITH 1 CARTRIDGE MKS 68045C
Completed
Completed
Last Edit:8 years 3 months ago by martin l
Time to create page: 5.313 seconds
