Subframe mounts & Cambelt
Subframe mounts & Cambelt was created by Simondi
Posted 8 years 3 weeks ago #173079
Just had my Cambelt, Water pump etc replaced by Mark at MB Autos Glasgow. Have to sya was very impressed with his workmanship.
I also had to get my subframe mounts replaced as well, they were scary to look at :omg:
Stainless coolant pipes now and jobs a good un
Last Edit:8 years 3 weeks ago by Simondi
Last edit: 8 years 3 weeks ago by David Aiketgate. Reason: clicked insert on photos
The following user(s) said Thank You: SundanceUK, Winko
Replied by Andy Lawrence on topic Subframe mounts & Cambelt
Posted 8 years 3 weeks ago #173080
Yep, there's "project drive" in full function.
WHALE OIL BEEF HOOKED
Replied by SundanceUK on topic Subframe mounts & Cambelt
Posted 8 years 3 weeks ago #173084
Unless your car has had the subframe mounts done, I doubt that there will not be many pre 2005 TF's that will not require this doing! Its also surprising how many MOT testers fail to pick up on these. Mine were rotten to bits and it still passed the MOT with no advisories, suffice to say I was shocked when I discovered them! Now changed and jobs a good un!
Sundance
[IMG
[IMG
The following user(s) said Thank You: Winko
Replied by sworkscooper on topic Subframe mounts & Cambelt
Posted 8 years 3 weeks ago #173096
Hells teeth , that's scary ! :(
Replied by mgtfbluestreak on topic Subframe mounts & Cambelt
Posted 8 years 3 weeks ago #173097
going to check mine out this winter....got plenty of time now to look around while its on a sorn........ :hgf:
Replied by Simondi on topic Re:RE: Subframe mounts & Cambelt
Posted 8 years 3 weeks ago #173112
sworkscooper wrote: Hells teeth , that's scary ! :(
Yep. :eek:
Sent from my LG-H850 using Tapatalk
by Simondi
Replied by adamelphick on topic Subframe mounts & Cambelt
Posted 8 years 2 weeks ago #173130
I've got a set of F ones that I am tempted ot fit as they are solid as arock and will give a little more fleximilty than the solid ones - not sure if that will help the ride or not?
Replied by Winko on topic Subframe mounts & Cambelt
Posted 8 years 2 weeks ago #173132
Thanks for this warning.
I'm trying to work out from the photos exactly where to look / inspect, but am failing. Can anyone help a blind old git?
by Winko
Posted 8 years 2 weeks ago #173133
Get the front end safely in the air then look up the back of the bumper and you should see rusty horror going on !!
In the first pic you can see the crash can and bumper brace to the right.
Last Edit:8 years 2 weeks ago by Andy Lawrence
Last edit: 8 years 2 weeks ago by Andy Lawrence.
Posted 8 years 2 weeks ago #173135
Thanks for that.
Glad you expanded your response, as when I read the first sentence, I thought you were talking about my wife...
by Winko
The following user(s) said Thank You: Andy Lawrence
Replied by Bob on topic Subframe mounts & Cambelt
Posted 8 years 2 weeks ago #173136
Mine are in very good condition on a 2002 car.
I swapped the front ones for stainless earlier in the year, but I was doing the wishbones so I changed them while I was there.
I suspect the car has been sat in a garage a lot in its life.
Last Edit:8 years 2 weeks ago by Bob
Last edit: 8 years 2 weeks ago by David Aiketgate.
Replied by championdaddy on topic Subframe mounts & Cambelt
Posted 8 years 2 weeks ago #173340
As a newby to TFs, and knowing that this is a job I'm having to do soon...........can I ask a couple of Qs please..................
1................... Does the bumper have to come off to access these ?
2....................Do you undo the Large center bolt first, then the the 4 small ones, or the other way round ?
3....................(stupid Q!!!!) Are these the rear mounts on the front subframe......or the front mounts on the rear subframe ???
Time to create page: 0.557 seconds
