MG TF GEAR CHANGE
  • Bobb
  • Apprentice MGer
  • Apprentice MGer
MG TF GEAR CHANGE was created by Bobb
Posted 5 years 1 month ago #195845
Hi, my MG TF 2002 gear change is a little stiff and sometimes it’s a little difficult to find gears. I don’t mean to over egg this as all gears are selectable and the car is a joy to drive, however if there was an easy fix I would be glad to hear it.
by Bobb
Replied by David Aiketgate on topic MG TF GEAR CHANGE
Posted 5 years 1 month ago #195846
Remove the gear surround and gaiter, to check and lubricate the change  mechs.
check the rear gear change mechanism at the bellhousing. The Rose joints do wear.
You can also adjust the cable lengths by screwing in the end joints.
Often the reverse cable needs shortening to help selection... Disconnect the Rose joint and screw in in 1 turn. There is a locking nut that you need to unloosen first.
Last Edit:5 years 1 month ago by David Aiketgate
Last edit: 5 years 1 month ago by David Aiketgate.
The following user(s) said Thank You: Bobb
Replied by talkingcars on topic MG TF GEAR CHANGE
Posted 5 years 1 month ago #195917
There is lots of info on gear change mechanisms in the how to guides.
Time to create page: 0.366 seconds
